MySql Spatial Database
Murat BEYHAN beyhan at DEPREM.GOV.TR
Thu Oct 5 02:23:31 EDT 2006
Dear Frank,
Thank you very much for your advice.
Now I store various kind of data in mysql database than I connect to database
and read data and draw layers on the map. It's really fantastic. Thank you to
mapserver,too.
Regards...
Murat
On Wed, 4 Oct 2006 10:49:10 -0400, Frank Warmerdam wrote
> Murat BEYHAN wrote:
> > Dear Bart,
> > thank you for your advice.
> > I have tried the followings
> > ogr2ogr -f MySQL MySQL:testogr,user=root,password=passmysql cities.shb -nln
> > iller -update -overwrite -lco GEOMETRY_NAME=SHAPE2
> > This is creates 3 tables in mysql tables in testogr database.
> > the names of the tables are
> > geometry_columns,
> > cities,
> > spatial_ref_sys
> > then I have doubt I have cities shape files the tail of the files are
> > shp shx sbn sbx these are esri files.  I don't know Which one should be use
> > for this?
> Murat,
> In the above commandline you show cities.shb as the input.  This should
> be cities.shp, perhaps this was just a typo if things worked?  Generally
> speaking OGR depends on the .shp, .shx and .dbf file.  The .sbn and .sbx
> spatial indexes are ignored.
> > And How can I connect and read data by using ogr connection from map file.
> You would use:
> CONNECTIONTYPE OGR
> CONNECTION "MySQL:testogr,user=root,password=passmysql"
> DATA "cities"
> for your layer.
> > I have an experiment if the data stored regularly as lat and lon in the table
> > I can read those for draw point. But My problem if I have polygone or line
> > data in mySql How can I read those data to create a layer on my map file by
> > using OGR. So I'm trying to use spatial database.
> Note that a true spatial table in MySQL is handled very differently from
> a table with lat and lon columns which is usually handled via ODBC
> and OVF.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
> This message has been scanned for viruses and
> dangerous content by MailScanner, and is
> believed to be clean.
Open WebMail Project (http://openwebmail.org)
