wms groups...
Laura Díaz Sánchez laura.diaz at IVER.ES
Thu Oct 5 02:24:59 EDT 2006
Hi John,
you can try gvSIG application as well:
http://www.gvsig.gva.es/index.php?id=gvsig&L=2
as a thick GIS client it lets you connect to WMS, supporting the layer
grouping,  you can try it with mapserver and other WMS implementations.
best regards,
Laura.
Bart van den Eijnden (OSGIS) wrote:
>> John,
>> this is not implemented in uDIG as far as I know.
>> Check Gaia (http://www.thecarbonportal.net/), it should work there.
>> Also check your WMS GetCapabilities response.
>> Best regards,
>> Bart
>> OSGIS, Open Source GIS
>> http://www.osgis.nl
>> --------- Oorspronkelijk bericht --------
>> Van: John Cole <john.cole at uai.com>
>> Naar: 'Bart van den Eijnden OSGIS' <bartvde at osgis.nl>
>> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
>> Onderwerp: RE: [UMN_MAPSERVER-USERS] wms groups...
>> Datum: 04/10/06 12:27
>>> Bart,
>>>   I've done just that, and I can't see the groups in uDig 1.1rc4.
>>> Should
>>> they show up?
>>> Thanks,
>>> John
>>> -----Original Message-----
>>> From: Bart van den Eijnden (OSGIS) [mailto:bartvde at osgis.nl] Sent:
>>> Tuesday, October 03, 2006 12:37 PM
>>> To: John Cole
>>> Subject: Re: [UMN_MAPSERVER-USERS] wms groups...
>>> You can just use GROUP, and then use wms_group_title IIRC.
>>> There is also a tag called wms_layer_group (METADATA), which can
>>> create a more than 1 level deep structure.
>>> Best regards,
>>> Bart
>>> John Cole schreef:
>>> &gt; Reading the WMS howto, I saw groups mentioned in the reference
>> section,
>>> but
>>> &gt; I'm a little confused.  How can I get WMS layers to act like the
>> mapserver
>>> &gt; layers GROUP tag?
>>> &gt;
>>> &gt; Thanks,
>>> &gt;
>>> &gt; John
>>> &gt; This email and any files transmitted with it are confidential and
>> intended
>>> solely for the use of the individual or entity to whom they are
>>> addressed.
>>> If you have received this email in error please notify the sender. This
>>> message contains confidential information and is intended only for the
>>> individual named. If you are not the named addressee you should not
>>> disseminate, distribute or copy this e-mail.
>>> &gt;
>>> &gt;
>>> &gt;
>>> http://www.osgis.nl
>>> intended
>> addressed.
