[UMN_MAPSERVER-USERS] Limit of 1 label per polygon
Léveillé, James
James.Leveille at MTQ.GOUV.QC.CA
Fri Oct 6 09:35:06 EDT 2006
Hi Stephen,
I didn't mean I actually had performance issues.
I just THOUGHT that the few calculations made by MapServer to check if more
than one label had to be placed in each polygon would be slower than
systematically placing only one label (less calculation). This is the reason
why I was asking.
Thanks.
James Léveillé
Intélec Géomatique
420, boul. Charest Est
Bureau 400
Québec (QC), Canada
G1K 8M4
Intélec Géomatique: 418.687.5000
MTQ: 418.380.2005 (#227)
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la
part de Stephen Woodbridge
Envoyé : 6 octobre 2006 09:15
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : Re: [UMN_MAPSERVER-USERS] Limit of 1 label per polygon
MINDISTANCE is exactly the tag you need for this, that is why it is
here. If you have a performance problem than tell us about that. What
makes you think MINDISTANCE would be slower than any other tag.
-Steve W.
Léveillé wrote:
> Hi,
> I have a layer of polygons. How can I make sure I have only one label
> per polygon ???
> I know there is a MINDISTANCE tag - which probably add overhead for
> calculation.
> Is there another tag that might be faster ?
> Thanks
> Regards
> Here is my layer :
> # Municipalité XYZ
> LAYER
> NAME "municipalite"
> PROJECTION
> "init=epsg:42105"
> END
> METADATA
> "wms_title" "Municipalité"
> "wms_name" "Municipalité"
> END
> STATUS ON
> DUMP TRUE
> EXTENT 30000 75000 1700000 2120000
> MAXSCALE 250000
> MINSCALE 1
> TYPE POLYGON
> DATA "bgr_v_muncp_genrl_act/bgr_v_muncp_genrl_act"
> LABELMAXSCALE 250000
> LABELMINSCALE 1
> CLASS
> OUTLINECOLOR 137 175 137
> TEXT ([NOM_MUNCP])
> LABEL
> TYPE TRUETYPE
> FONT "arial"
> SIZE 8
> COLOR 137 175 137
> OUTLINECOLOR 255 255 255
> POSITION CC
> END
> END
> END
> *James Léveillé*
> *Intélec Géomatique*
> Bureau 400
> Québec (QC), Canada
> G1K 8M4
