Help: generating a hyperlink in query result
Xiaopeng Xiong
xpxiong at PURDUE.EDU
Tue Oct 10 14:50:11 EDT 2006
MessageI probably want the second way. A difference is that the clickable links are not exactly the same as the attribute values in the index, because I have to change a UNIX file path (e.g., /home/MyDir/1.img) to a Web-accessible path (e.g., http://SomeWeb/MyDir/1.img).
Thanks,
Xiaopeng
----- Original Message -----
To: MAPSERVER-USERS at LISTS.UMN.EDU
Sent: Tuesday, October 10, 2006 2:40 PM
Subject: Re: [UMN_MAPSERVER-USERS] Help: generating a hyperlink in query result
Are you interested in having the user click on the map and be directed automatically to another Web page? This could be done using a URL as a query template and setting the mode to query.
Or, do you want the user to click on the map, presumably as a query and return a page or text on the existing page that includes a list of clickable links?
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Xiaopeng Xiong
Sent: Tuesday, October 10, 2006 1:23 PM
Jacob, thank for your reply.
I think your method generates hyperlinks after post-processing of query result. But I wonder if it is possible to return hyperlinks to a uer directly when he/she clicks on the map. I wonder it is possible?
Thanks,
Xiaopeng
To: Xiaopeng Xiong ; MAPSERVER-USERS at LISTS.UMN.EDU
Sent: Tuesday, October 10, 2006 12:11 AM
Subject: RE: [UMN_MAPSERVER-USERS] Help: generating a hyperlink in query result
Hi Xiaopeng,
If the attribute value is simply passed into the HTML, then it's simply a matter of putting in the right HTML code:
<a href="http://someWebsite/myDir/1.img" target=#>Click for 1.img</a> (the target=# makes it open in a new window)
I normally generate a directory listing, and paste it into a spreadsheet (e.g. excel / openOffice CALC), and split up the parts of the link, then concatenate them. For example, imagine a row in a spreadsheet:
column 1: <a href="http://someWebsite/mydir/
column 2: 1
column 3: ".img target=#>
column 4: click for image
column 5: 1
column 6: </a>
column 7: =concatenate(column1, column2, column3, column4, column6)
Only column 2 and 5 will change (can use autonumber). All other columns will hold the same value, and can be copied across.
Hope this makes sense.
regards,
Jacob
Sent: 10 October 2006 11:42
Subject: [UMN_MAPSERVER-USERS] Help: generating a hyperlink in query result
I have one index on raster images and it can be displayed and queried through Mapserver.
I wonder whether it would be possible to generate a hyperlink in query result.
The hyperlink will be generated based on one attribute in the index.
For example, if the attribute value is "/home/myDir/1.img", the hyperlink will direct user to http://SomeWebsite/myDir/1.img".
I appreciate any suggestions or ideas.
Thank you
Best regards,
Xiaopeng
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061010/8ed7ed2c/attachment.html
