Enable zip file downloading from query results
Delfos, Jacob
Jacob.Delfos at MAUNSELL.COM
Thu Oct 12 23:29:38 EDT 2006
Hi Xiaopeng,
There is a file from "Catalist Creative" on their website, which does
that:
http://www.catalistcreative.com/tools/zipfile.php.txt
I have used it a fair bit for this purpose. You basically have to modify
it to point to the right files. If you use it, please make the following
change, otherwise you will run into problems if you try to open the
zip-file straight from Internet Explorer:
Before the lines that say "Header ("Content ........", put another line
that says:
Header("Cache-Control: must-revalidate, post-check=0, pre-check=0");
regards,
Jacob
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Xiaopeng Xiong
Sent: 13 October 2006 09:19
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Enable zip file downloading from
query results
Hello List,
I am very new to this field. I apologize if this question is not
related but I do appreciate any suggestions.
I have one index that can be queried using mapserver. The query
results are like follows:
Record | UL_X | FileLink
1 456000 http://myweb.com/photo/15.tif
2 460000 http://myweb.com/photo/38.tif
3 464000 http://myweb.com/photo/41.tif
Now what I want to realize is to provide an additional
"Download_All" button in the query result page.
Then when the user clicks the "Download_All" button, all the
files in "FileLink" will be compressed online
into one (e.g., .zip) file and downloaded.
How can this be realized? I'll apprecate any help or some
reference to read.
Thank you.
Best,
Xiaopeng
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061013/a279a438/attachment.html
