Enable zip file downloading from query results
Xiaopeng Xiong
xpxiong at PURDUE.EDU
Fri Oct 13 12:13:30 EDT 2006
Thank Jacob, I will look into it.
I am not quite familiar with Php, so I am spending time learning how to make it work.
Thanks again.
Xiaopeng
----- Original Message -----
To: Xiaopeng Xiong ; MAPSERVER-USERS at LISTS.UMN.EDU
Sent: Thursday, October 12, 2006 11:29 PM
Subject: RE: [UMN_MAPSERVER-USERS] Enable zip file downloading from query results
Hi Xiaopeng,
There is a file from "Catalist Creative" on their website, which does that:
http://www.catalistcreative.com/tools/zipfile.php.txt
I have used it a fair bit for this purpose. You basically have to modify it to point to the right files. If you use it, please make the following change, otherwise you will run into problems if you try to open the zip-file straight from Internet Explorer:
Before the lines that say "Header ("Content ........", put another line that says:
Header("Cache-Control: must-revalidate, post-check=0, pre-check=0");
regards,
Jacob
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Xiaopeng Xiong
Sent: 13 October 2006 09:19
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Enable zip file downloading from query results
Hello List,
I am very new to this field. I apologize if this question is not related but I do appreciate any suggestions.
I have one index that can be queried using mapserver. The query results are like follows:
Record | UL_X | FileLink
1 456000 http://myweb.com/photo/15.tif
2 460000 http://myweb.com/photo/38.tif
3 464000 http://myweb.com/photo/41.tif
Now what I want to realize is to provide an additional "Download_All" button in the query result page.
Then when the user clicks the "Download_All" button, all the files in "FileLink" will be compressed online
into one (e.g., .zip) file and downloaded.
How can this be realized? I'll apprecate any help or some reference to read.
Thank you.
Best,
Xiaopeng
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061013/ac2bcb87/attachment.html
