Reading grass vector files with mapserver
Francisco Alonso Sarría
alonsarp at UM.ES
Sat Oct 14 22:06:35 EDT 2006
Hi:
I want to include some GRASS vector maps into a mapserver file map.
As an example:
LAYER
NAME municipios
TYPE POLYGON
STATUS ON
CONNECTIONTYPE OGR
CONNECTION /data/grassdata/atlas/alonso/vector/municipios/head
TOLERANCE 5
DATA "1"
DUMP TRUE
CLASS
NAME "5"
EXPRESSION ( [cod_comarc] = 5 )
COLOR 245 245 0
OUTLINECOLOR 0 0 0
LABEL
#TYPE truetype
# FONT arial
POSITION CC
SIZE SMALL
COLOR 0 0 225
END
END
Classifying the polygons according to the column "cod_comarc" in the
database.
The problem is that I can not access that database (if I change to:
EXPRESSION ( [cat] = 5 )
works fine).
Browsing messages in the Internet I have found that it is related with
the need of passing the GISBASE environmental variable. As a matter of
fact if I try:
$ ogrinfo -ro /data/grassdata/atlas/alonso/vector/municipios/head
Warning 1: GRASS warning: GISBASE enviroment variable was not set,
using:
/usr/local/grass-6.3.cvs
INFO: Open of `/data/grassdata/atlas/alonso/vector/municipios/head'
using driver `GRASS' successful.
1: 0
2: 1
I obtain an error that looks similar, but if I do:
export GISBASE=/usr/local/grass-6.3.cvs;ogrinfo
1: 0
2: 1
Everything works fine.
So the question is how to pass GISBASE to mapserv and to PHPmapscript
scripts. I have tried adding:
SetEnv GISBASE /usr/local/grass-6.3.cvs
to the http.conf and it doesn't work
Any suggestion?
Thanks in advance.
Paco
Departamento de Geografía.
Univ. de Murcia E-30001-Murcia
+34 968364357
http://www.um.es/geograf/sigmur
+34 968364357
