labelling please help
Travis Kirstine tkirstine at JDBARNES.COM
Fri Oct 13 08:33:45 EDT 2006
Sandeep, you have many conflicting declarations in your mapfile i.e.
  LABELMAXSCALE  10014
  LABELMINSCALE  10014
I would simplify it a bit then add additional declarations once you have it
working to something like:
LAYER
   NAME "roads_polyline"
   TYPE LINE
   STATUS ON
   DATA "C:/GIS-Data/ESRI Data/roads_polyline"
   LABELITEM "id"
   LABELMAXSCALE  100000
   LABELMINSCALE  100
  CLASS
      NAME "Roads_polyline"
      COLOR 255 255 0
      SYMBOL 'lg'
      SIZE 10
      LABEL
         COLOR 0 0 0
         ANGLE AUTO
         TYPE TRUETYPE
         FONT arial
         SIZE 12
      END
   END
END
  -----Original Message-----
  From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Sandeep Kumar Jakkaraju
  Sent: Friday, October 13, 2006 8:15 AM
  To: MAPSERVER-USERS at LISTS.UMN.EDU
  Subject: Re: [UMN_MAPSERVER-USERS] labelling please help
  This the Map file I am using ... i am unable to label it !!
  NAME delhimap
  STATUS ON
  # Map image size. Change size as desired
  SIZE 2156 1674
  # Start of web interface definition. Only the TEMPLATE parameter
  # must be specified to display a map. See Mapserver documentation
  WEB
    HEADER Delhi
    TEMPLATE Delhi
    FOOTER Delhi
    MINSCALE 100
    MAXSCALE 10000
  # Set IMAGEPATH to the path where mapserver should
  # write its output
   IMAGEPATH 'C:/ms4w/apps/test/htdocs/'
  # Set IMAGEURL to the url that points to IMAGEPATH
   #IMAGEURL 'C:/ms4w/apps/test/htdocs/'
  END
  # Extent based on full extent of QGIS view
  #EXTENT 77.2018 28.6023 77.2493 28.6382
  EXTENT 77.19591 28.6000042 77.25517 28.640461
  UNITS meters
  #IMAGECOLOR 255 255 255
  IMAGECOLOR 0 128 255
  IMAGETYPE jpeg
  # Projection definition
  # Projections are not currenlty supported. If desired, add your own
  # projection information based on Mapserver documentation.
  LAYER
    TYPE LINE
    STATUS ON
    LABELANGLEITEM "0"
    LABELCACHE ON
    LABELITEM "id"
    LABELREQUIRES "true"
    LABELMAXSCALE  10014
    LABELMINSCALE  10014
    LABELSIZEITEM  "5"
    CLASS
      TEXT "Road"
      # TEMPLATE
      #OUTLINECOLOR 207 150 123
       OUTLINECOLOR 255 255 0
       STYLE
   COLOR 255 255 0
   SYMBOL 'lg'
   SIZE 10
       END
       LABEL
        COLOR 0 0 0
        ANGLE AUTO
        MINSIZE 10
       END
    END
  END
  SYMBOL
   NAME 'lg'
   TYPE ELLIPSE
   POINTS
    1 1
   END
   STYLE
    10 0 10 0
   END
  END
  END # Map File
  On 10/13/06, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
    Sandeep Kumar Jakkaraju wrote:
    > I have put the following in my map file
    >   LABELANGLEITEM "0"
    >   LABELCACHE ON
    >   LABELITEM "id"
    >   LABELMAXSCALE  10014
    >   LABELMINSCALE  10014
    >   LABELSIZEITEM  "5"
    > But still i dont see any labels
    > please help !!
    You probably need to post the whole LAYER definition for us to be able
    to help.
  WeBlog:
  http://jakkarajus.blogspot.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061013/448564cd/attachment.html
