labelling please help
Sandeep Kumar Jakkaraju
sandeepkumar.jakkaraju at GMAIL.COM
Sat Oct 14 02:30:55 EDT 2006
Hi Travis
I tried ur declarations ... it is also not working ....
I am unable to label ... !!! please help
my Mapfile now is
NAME delhimap
STATUS ON
SIZE 2156 1674
WEB
HEADER Delhi
TEMPLATE Delhi
FOOTER Delhi
MINSCALE 100
MAXSCALE 10000
IMAGEPATH 'C:/ms4w/apps/test/htdocs/'
IMAGEURL 'C:/ms4w/apps/test/htdocs/'
END
EXTENT 77.19591 28.6000042 77.25517 28.640461
UNITS meters
IMAGECOLOR 226 226 233
IMAGETYPE jpeg
LAYER
NAME "roads_polyline"
TYPE LINE
STATUS ON
DATA "C:/GIS-Data/ESRI Data/roads_polyline"
LABELITEM "id"
LABELMAXSCALE 100000
LABELMINSCALE 100
CLASS
NAME "Roads_polyline"
# TEMPLATE
OUTLINECOLOR 255 255 249
STYLE
COLOR 0 0 0
SYMBOL 'lg'
SIZE 8
END
STYLE
COLOR 253 255 166
SYMBOL 'lg'
SIZE 6
END
LABEL
COLOR 0 0 0
ANGLE AUTO
TYPE TRUETYPE
FONT arial
SIZE 12
END
END
END
SYMBOL
NAME 'lg'
TYPE ELLIPSE
POINTS
1 1
END
STYLE
10 0 10 0
END
END
END
Thanks.
On 10/13/06, Travis Kirstine <tkirstine at jdbarnes.com> wrote:
> Sandeep, you have many conflicting declarations in your mapfile i.e.
> LABELMAXSCALE 10014
> LABELMINSCALE 10014
> I would simplify it a bit then add additional declarations once you have
> it working to something like:
> LAYER
> TYPE LINE
> STATUS ON
> LABELITEM "id"
> LABELMINSCALE 100
> CLASS
> COLOR 255 255 0
> SYMBOL 'lg'
> SIZE 10
> LABEL
> COLOR 0 0 0
> ANGLE AUTO
> TYPE TRUETYPE
> FONT arial
> SIZE 12
> END
> END
> END
> -----Original Message-----
> *From:* UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]*On
> Behalf Of *Sandeep Kumar Jakkaraju
> *Sent:* Friday, October 13, 2006 8:15 AM
> *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> *Subject:* Re: [UMN_MAPSERVER-USERS] labelling please help
> This the Map file I am using ... i am unable to label it !!
> NAME delhimap
> STATUS ON
> # Map image size. Change size as desired
> SIZE 2156 1674
> # Start of web interface definition. Only the TEMPLATE parameter
> # must be specified to display a map. See Mapserver documentation
> WEB
> HEADER Delhi
> TEMPLATE Delhi
> FOOTER Delhi
> MINSCALE 100
> MAXSCALE 10000
> # Set IMAGEPATH to the path where mapserver should
> # write its output
> # Set IMAGEURL to the url that points to IMAGEPATH
> #IMAGEURL 'C:/ms4w/apps/test/htdocs/'
> END
> # Extent based on full extent of QGIS view
> #EXTENT 77.2018 28.6023 77.2493 28.6382
> UNITS meters
> #IMAGECOLOR 255 255 255
> IMAGECOLOR 0 128 255
> IMAGETYPE jpeg
> # Projection definition
> # Projections are not currenlty supported. If desired, add your own
> # projection information based on Mapserver documentation.
> LAYER
> TYPE LINE
> STATUS ON
> LABELANGLEITEM "0"
> LABELCACHE ON
> LABELITEM "id"
> LABELREQUIRES "true"
> LABELMAXSCALE 10014
> LABELMINSCALE 10014
> LABELSIZEITEM "5"
> CLASS
> TEXT "Road"
> # TEMPLATE
> #OUTLINECOLOR 207 150 123
> OUTLINECOLOR 255 255 0
> STYLE
> COLOR 255 255 0
> SYMBOL 'lg'
> SIZE 10
> END
> LABEL
> COLOR 0 0 0
> ANGLE AUTO
> MINSIZE 10
> END
> END
> END
> SYMBOL
> NAME 'lg'
> TYPE ELLIPSE
> POINTS
> 1 1
> END
> STYLE
> 10 0 10 0
> END
> END
> END # Map File
> On 10/13/06, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> > Sandeep Kumar Jakkaraju wrote:
> > > I have put the following in my map file
> > > LABELANGLEITEM "0"
> > > LABELCACHE ON
> > > LABELITEM "id"
> > > LABELMAXSCALE 10014
> > > LABELMINSCALE 10014
> > > LABELSIZEITEM "5"
> > > But still i dont see any labels
> > > please help !!
> > You probably need to post the whole LAYER definition for us to be able
> > to help.
> WeBlog:
> http://jakkarajus.blogspot.com
WeBlog:
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061014/90addd48/attachment.html
