- SOLUTION (sort of) Am I correct in assuming this won't work? (map_web_template=select_html)
Bob Basques bob.b at GRITECHNOLOGIES.COM
Fri Oct 13 22:27:49 EDT 2006
All,
Hmmm, after some experimentation, this does work:
map_legend_template=select_leg.html
Not exactly what I need, but I think it will work OK for me now, I just
need to copy a few things in the BROWSE html template this way.
Funny though that the LEGEND works, but the WEB object doesn't.
Hmmmm.
bobb
Bob Basques wrote:
> All,
> I'm trying to generate a different LEGEND (then specified in the
> MapFILE) by passing a CGI request to MapSever with a MAPFILE parameter
> change:
> map_web_template=select.html (Am I correct in assuming that the
> map_legend_template=<something else> would react the same way?)
> This doesn't seem to have any effect though.
> Should this work?  Or is it one of those few things that can't be
> changed via the URL?  Only intended for Layer stuff for example.
> Thanks
> bobb
