Strange OGR VRT Issue
Pascoe,Tim [Burlington] Tim.Pascoe at EC.GC.CA
Fri Oct 13 09:30:48 EDT 2006
Murat,
            Thanks for the suggestion. Unfortunalty, this has had no effect on the behavior. Also, how would I do this if I had a SELECT statement involving more tables? Or would I just put all the tables in the list?
Timothy Pascoe
Environmental Systems Scientist
Environment Canada / Environnement Canada
Canada Centre for Inland Waters / Centre Canadien des Eaux Intérieures
867 Lakeshore Road / 867, chemin Lakeshore
Burlington, Ontario / Burlington (Ontario)
L7R 4A6
Tel/Tél: (905) 336-6239
Fax/Téléc: (905) 336-4699
E-mail/C. élec: tim.pascoe at ec.gc.ca <mailto:tim.pascoe at ec.gc.ca>
Government of Canada/Gouvernement du Canada
This e-mail represents the opinions and views solely held by its author and in no manner may be considered as representing those of his/her employer.
  _____
From: Murat BEYHAN [mailto:beyhan at deprem.gov.tr]
Sent: October 12, 2006 3:58 PM
To: Pascoe,Tim [Burlington]; MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Strange OGR VRT Issue
Tom,
At the following line I think, but I'm not sure, You should write the name of table as your old ovf file.
>         <SrcDataSource>ODBC:****/****@CABIN</SrcDataSource>
Please try to change the line as follows,
<SrcDataSource>ODBC:****/****@CABIN</SrcDataSource,OGRPoints>
Good luck...
Murat
On Thu, 12 Oct 2006 13:10:33 -0400, Pascoe,Tim [Burlington] wrote
> I'm experimenting with placing my OVF file in line, in order to pass in some variables for a custom WHERE Statement. The first step I took was changing my OVF file to use the scrSQL tag with a very simple SQL statement, instead of the srcLayer tag. Both OVF files point to the same view, in the same database.
> New File:
> <OGRVRTDataSource>
>     <OGRVRTLayer name="CABINPoints">
>         <SrcSQL>SELECT * FROM OGRPoints</SrcSQL>
>           <FID>sitedetailsid</FID>
>         <GeometryType>wkbPoint</GeometryType>
>         <LayerSRS>WGS84</LayerSRS>
>     <GeometryField encoding="PointFromColumns" x="longitude" y="latitude"/>
>     </OGRVRTLayer>
> </OGRVRTDataSource>
> Old FIle:
> <OGRVRTDataSource>
>         <SrcDataSource>ODBC:****/****@CABIN,OGRPoints</SrcDataSource>
>         <SrcLayer>OGRPoints</SrcLayer>
>     </OGRVRTLayer>
> </OGRVRTDataSource>
> The problem is, the old OVF returns a proper image, while the new one returns a blank image. I ran the new file through OGRInfo and shp2ogr, and both behave properly.
> So........why am I getting a blank image with the scrSQL tag? I'm using the latest version of the MS4W file set, but running on IIS on Windows 2000. Any suggestions would be great - it's probably somthing very simple I'm missing :)
> Tim Pascoe
> This message has been scanned for viruses and
> dangerous content by MailScanner <http://www.mailscanner.info/> , and is
> believed to be clean.
Open WebMail Project (http://openwebmail.org <http://openwebmail.org/> )
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061013/9de4b5b4/attachment.html
