labelling please help
Sandeep Kumar Jakkaraju sandeepkumar.jakkaraju at GMAIL.COM
Sat Oct 14 08:14:17 EDT 2006
Thank you everyone...
I figured out the problem ... it had to do with the min and max scale ...
Thanks again.
Sandeep
On 10/14/06, Wim Blanken <w.blanken at geon.nl> wrote:
>  Hello Sandeep,
> I Think you have to use the uppercase variant of id so ID in your
> labelitem section.
> Regards,
> Wim Blanken
> *From:* UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] *On
> Behalf Of *Sandeep Kumar Jakkaraju
> *Sent:* zaterdag 14 oktober 2006 8:31
> *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> *Subject:* Re: [UMN_MAPSERVER-USERS] labelling please help
> Hi Travis
> I tried ur declarations ... it is also not working ....
> I am unable to label ... !!! please help
> my Mapfile now is
> NAME delhimap
> STATUS ON
> SIZE 2156 1674
> WEB
>   HEADER Delhi
>   TEMPLATE Delhi
>   FOOTER Delhi
>   MINSCALE 100
>   MAXSCALE 10000
>   IMAGEPATH 'C:/ms4w/apps/test/htdocs/'
>   IMAGEURL 'C:/ms4w/apps/test/htdocs/'
> END
> EXTENT 77.19591 28.6000042 77.25517 28.640461
> UNITS meters
> IMAGECOLOR 226 226 233
> IMAGETYPE jpeg
> LAYER
>   NAME "roads_polyline"
>   TYPE LINE
>   STATUS ON
>   DATA "C:/GIS-Data/ESRI Data/roads_polyline"
>   LABELITEM "id"
>   LABELMAXSCALE  100000
>   LABELMINSCALE  100
>   CLASS
>     NAME "Roads_polyline"
>     # TEMPLATE
>     OUTLINECOLOR 255 255 249
>      STYLE
>         COLOR 0 0 0
>  SYMBOL 'lg'
>  SIZE 8
>      END
>      STYLE
>  COLOR 253 255 166
>  SYMBOL 'lg'
>  SIZE 6
>      END
>      LABEL
>       COLOR 0 0 0
>       ANGLE AUTO
>       TYPE TRUETYPE
>       FONT arial
>       SIZE 12
>      END
>   END
> END
> SYMBOL
>  NAME 'lg'
>  TYPE ELLIPSE
>  POINTS
>   1 1
>  END
>  STYLE
>   10 0 10 0
>  END
> END
> END
> Thanks.
> On 10/13/06, *Travis Kirstine* <tkirstine at jdbarnes.com> wrote:
> Sandeep, you have many conflicting declarations in your mapfile i.e.
>   LABELMAXSCALE  10014
>   LABELMINSCALE  10014
> I would simplify it a bit then add additional declarations once you have
> it working to something like:
> LAYER
>    TYPE LINE
>    STATUS ON
>    LABELITEM "id"
>    LABELMINSCALE  100
>   CLASS
>       COLOR 255 255 0
>       SYMBOL 'lg'
>       SIZE 10
>       LABEL
>          COLOR 0 0 0
>          ANGLE AUTO
>          TYPE TRUETYPE
>          FONT arial
>          SIZE 12
>       END
>    END
> END
> -----Original Message-----
> *From:* UMN MapServer Users List [mailto: MAPSERVER-USERS at LISTS.UMN.EDU]*On
> *Sent:* Friday, October 13, 2006 8:15 AM
> This the Map file I am using ... i am unable to label it !!
> NAME delhimap
> STATUS ON
> # Map image size. Change size as desired
> SIZE 2156 1674
> # Start of web interface definition. Only the TEMPLATE parameter
> # must be specified to display a map. See Mapserver documentation
> WEB
>   HEADER Delhi
>   TEMPLATE Delhi
>   FOOTER Delhi
>   MINSCALE 100
>   MAXSCALE 10000
> # Set IMAGEPATH to the path where mapserver should
> # write its output
> # Set IMAGEURL to the url that points to IMAGEPATH
>  #IMAGEURL 'C:/ms4w/apps/test/htdocs/'
> END
> # Extent based on full extent of QGIS view
> #EXTENT 77.2018 28.6023 77.2493 28.6382
> UNITS meters
> #IMAGECOLOR 255 255 255
> IMAGECOLOR 0 128 255
> IMAGETYPE jpeg
> # Projection definition
> # Projections are not currenlty supported. If desired, add your own
> # projection information based on Mapserver documentation.
> LAYER
>   TYPE LINE
>   STATUS ON
>   LABELANGLEITEM "0"
>   LABELCACHE ON
>   LABELITEM "id"
>   LABELREQUIRES "true"
>   LABELMAXSCALE  10014
>   LABELMINSCALE  10014
>   LABELSIZEITEM  "5"
>   CLASS
>     TEXT "Road"
>     # TEMPLATE
>     #OUTLINECOLOR 207 150 123
>      OUTLINECOLOR 255 255 0
>      STYLE
>  COLOR 255 255 0
>  SYMBOL 'lg'
>  SIZE 10
>      END
>      LABEL
>       COLOR 0 0 0
>       ANGLE AUTO
>       MINSIZE 10
>      END
>   END
> END
> SYMBOL
>  NAME 'lg'
>  TYPE ELLIPSE
>  POINTS
>   1 1
>  END
>  STYLE
>   10 0 10 0
>  END
> END
> END # Map File
> On 10/13/06, *Stephen Woodbridge* <woodbri at swoodbridge.com > wrote:
> Sandeep Kumar Jakkaraju wrote:
> > I have put the following in my map file
> >   LABELANGLEITEM "0"
> >   LABELCACHE ON
> >   LABELITEM "id"
> >   LABELMAXSCALE  10014
> >   LABELMINSCALE  10014
> >   LABELSIZEITEM  "5"
> > But still i dont see any labels
> > please help !!
> You probably need to post the whole LAYER definition for us to be able
> to help.
> WeBlog:
> http://jakkarajus.blogspot.com
> WeBlog:
WeBlog:
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061014/abbf2910/attachment.html
