labelling please help
Wim Blanken w.blanken at GEON.NL
Sat Oct 14 07:43:11 EDT 2006
Hello Sandeep,
I Think you have to use the uppercase variant of id so ID in your labelitem
section.
Regards,
Wim Blanken
  _____
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Sandeep Kumar Jakkaraju
Sent: zaterdag 14 oktober 2006 8:31
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] labelling please help
Hi Travis
I tried ur declarations ... it is also not working ....
I am unable to label ... !!! please help
my Mapfile now is
NAME delhimap
STATUS ON
SIZE 2156 1674
WEB
  HEADER Delhi
  TEMPLATE Delhi
  FOOTER Delhi
  MINSCALE 100
  MAXSCALE 10000
  IMAGEPATH 'C:/ms4w/apps/test/htdocs/'
  IMAGEURL 'C:/ms4w/apps/test/htdocs/'
END
EXTENT 77.19591 28.6000042 77.25517 28.640461
UNITS meters
IMAGECOLOR 226 226 233
IMAGETYPE jpeg
LAYER
  NAME "roads_polyline"
  TYPE LINE
  STATUS ON
  DATA "C:/GIS-Data/ESRI Data/roads_polyline"
  LABELITEM "id"
  LABELMAXSCALE  100000
  LABELMINSCALE  100
  CLASS
    NAME "Roads_polyline"
    # TEMPLATE
    OUTLINECOLOR 255 255 249
     STYLE
        COLOR 0 0 0
 SYMBOL 'lg'
 SIZE 8
     END
     STYLE
 COLOR 253 255 166
 SYMBOL 'lg'
 SIZE 6
     END
     LABEL
      COLOR 0 0 0
      ANGLE AUTO
      TYPE TRUETYPE
      FONT arial
      SIZE 12
     END
  END
END
SYMBOL
 NAME 'lg'
 TYPE ELLIPSE
 POINTS
  1 1
 END
 STYLE
  10 0 10 0
 END
END
END
Thanks.
On 10/13/06, Travis Kirstine <tkirstine at jdbarnes.com> wrote:
Sandeep, you have many conflicting declarations in your mapfile i.e.
  LABELMAXSCALE  10014
  LABELMINSCALE  10014
I would simplify it a bit then add additional declarations once you have it
working to something like:
LAYER
   TYPE LINE
   STATUS ON
   LABELITEM "id"
   LABELMINSCALE  100
  CLASS
      COLOR 255 255 0
      SYMBOL 'lg'
      SIZE 10
      LABEL
         COLOR 0 0 0
         ANGLE AUTO
         TYPE TRUETYPE
         FONT arial
         SIZE 12
      END
   END
END
-----Original Message-----
<mailto:MAPSERVER-USERS at LISTS.UMN.EDU>  MAPSERVER-USERS at LISTS.UMN.EDU]On
Sent: Friday, October 13, 2006 8:15 AM
This the Map file I am using ... i am unable to label it !!
NAME delhimap
STATUS ON
# Map image size. Change size as desired
SIZE 2156 1674
# Start of web interface definition. Only the TEMPLATE parameter
# must be specified to display a map. See Mapserver documentation
WEB
  HEADER Delhi
  TEMPLATE Delhi
  FOOTER Delhi
  MINSCALE 100
  MAXSCALE 10000
# Set IMAGEPATH to the path where mapserver should
# write its output
# Set IMAGEURL to the url that points to IMAGEPATH
 #IMAGEURL 'C:/ms4w/apps/test/htdocs/'
END
# Extent based on full extent of QGIS view
#EXTENT 77.2018 28.6023 77.2493 28.6382
UNITS meters
#IMAGECOLOR 255 255 255
IMAGECOLOR 0 128 255
IMAGETYPE jpeg
# Projection definition
# Projections are not currenlty supported. If desired, add your own
# projection information based on Mapserver documentation.
LAYER
  TYPE LINE
  STATUS ON
  LABELANGLEITEM "0"
  LABELCACHE ON
  LABELITEM "id"
  LABELREQUIRES "true"
  LABELMAXSCALE  10014
  LABELMINSCALE  10014
  LABELSIZEITEM  "5"
  CLASS
    TEXT "Road"
    # TEMPLATE
    #OUTLINECOLOR 207 150 123
     OUTLINECOLOR 255 255 0
     STYLE
 COLOR 255 255 0
 SYMBOL 'lg'
 SIZE 10
     END
     LABEL
      COLOR 0 0 0
      ANGLE AUTO
      MINSIZE 10
     END
  END
END
SYMBOL
 NAME 'lg'
 TYPE ELLIPSE
 POINTS
  1 1
 END
 STYLE
  10 0 10 0
 END
END
END # Map File
On 10/13/06, Stephen Woodbridge <woodbri at swoodbridge.com
<mailto:woodbri at swoodbridge.com> > wrote:
Sandeep Kumar Jakkaraju wrote:
> I have put the following in my map file
>   LABELANGLEITEM "0"
>   LABELCACHE ON
>   LABELITEM "id"
>   LABELMAXSCALE  10014
>   LABELMINSCALE  10014
>   LABELSIZEITEM  "5"
> But still i dont see any labels
> please help !!
You probably need to post the whole LAYER definition for us to be able
to help.
WeBlog:
http://jakkarajus.blogspot.com <http://jakkarajus.blogspot.com/>
WeBlog:
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061014/400ead97/attachment.html
