Query template + javascript?
Richard Greenwood
richard.greenwood at GMAIL.COM
Mon Oct 16 15:50:07 EDT 2006
On 10/16/06, Xiaopeng Xiong <xpxiong at purdue.edu> wrote:
> I tried to add javascript to query templates. But it stops working by even
> declaring to use javascript.
> As in the following example:
> -----Header.html-------
> <html>
> <head></head>
> <body>
> <script language = "javascript"> //* after adding this statement, the
> result page becomes empty
> document.write("Just hello"); //* this does not work neither...
> ----Template.html-------
> <tr><td>[LABEL]</td><tr>
> ----Footer.html------
> </script>
> </body>
> It returns the query results correctly if the * statements are not inserted.
> But after adding the * statements, the result page becomes blank.
> Can anyone give a hint?
> Thanks,
> Xiaopeng
Move your closing </script> tag up to the line after document.write.
You hace HTML inside your javascript.
Also note that <script type="text/javascript"> is prefered to <script
Also check your javascript console for errors.
I use a lot of javascript in my templates and it works fine.
Rich
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
