Query template + javascript?
Xiaopeng Xiong xpxiong at PURDUE.EDU
Mon Oct 16 16:30:49 EDT 2006
Okay, it is working now after some trials
What I did is to add both <script language = "javascript"> and </script> in each header, footer and template html, rather than split them in header and footer html ...
Regards,
Xiaopeng
  ----- Original Message -----
  To: MAPSERVER-USERS at LISTS.UMN.EDU
  Sent: Monday, October 16, 2006 3:44 PM
  Subject: [UMN_MAPSERVER-USERS] Query template + javascript?
  I tried to add javascript to query templates. But it stops working by even declaring to use javascript.
  As in the following example:
  -----Header.html-------
  <html>
  <head></head>
  <body>
  <script language = "javascript">  //* after adding this statement, the result page becomes empty
  document.write("Just hello");  //* this does not work neither...
  ----Template.html-------
  <tr><td>[LABEL]</td><tr>
  ----Footer.html------
  </script>
  </body>
  It returns the query results correctly if the * statements are not inserted. But after adding the * statements, the result page becomes blank.
  Can anyone give a hint?
  Thanks,
  Xiaopeng
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061016/2a3bce82/attachment.html
