vertical labels
Nuria González nataprivate at HOTMAIL.COM
Tue Oct 17 04:12:24 EDT 2006
Hi all,
I'm using MapServer version 4.6.1 on Windows XP.
I want to display the label of layers in vertical position, not horizontal
position. I saw the label ANGLE to rotate the label, but I understood that
it's for TrueType fonts. Then, I set a FONSET label and FONT and TYPE
TRUETYPE in my .map file, but I get an error:
([MapServer Error]: msGetLabelSize(): Requested font (arial) not found), but
I've revised all the paths and font.list file and it's ok for me.
I attach you the fonts.list and .map files. The "Conventus Scallabitanus" in
the layer "Conventus" is the class that I want to display the vertical
label. In the "fonts" folder there are the fonts.list and the letters types
files.
How can I resolve this problem?
Do you know a way to set vertical labels?
TIA.
_________________________________________________________________
¿Estás pensando en cambiar de coche? Todas los modelos de serie y extras en
MSN Motor. http://motor.msn.es/researchcentre/
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061017/39a54ca4/demo.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061017/39a54ca4/fonts.obj
