imagemap output mode no longer working with 4.10
Fawcett, David
David.Fawcett at STATE.MN.US
Tue Oct 17 15:46:28 EDT 2006
Dylan,
Do you see this behavior in 4.10 CGI, or just in phpMapScript 4.10.
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Dylan Beaudette
Sent: Tuesday, October 17, 2006 1:39 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] imagemap output mode no longer
working with 4.10
Thank Steve.
If there are any diagnostics I can perform to help nail down the culprit
please let me know. The short explanation: with 4.8.x imagemap output
works
as expected and documented. As of 4.10 there is an empty imagemap
returned.
Cheers,
PS: is there a handy link to the bugtracker near?
Dylan
On Monday 16 October 2006 16:45, Steve Lime wrote:
> You'll have to file a bug for this. There was a benign patch applied
> in 4.10 that could be the culprit but we'd more information of
> before/after output to be sure.
> Steve
> >>> Dylan Beaudette <dylan.beaudette at GMAIL.COM> 10/12/2006 7:36:59 PM
> Hi,
> I have been using the imagemap output driver since mapserver 4.6
> without issue. Today, after updating to 4.10 I notice that the only
> result from a
> mapfile, rendered with phpmapscript, and using the imagemap output
> driver is:
> <map name="map1" width="450" height="500">
> </map>
> if i switch the output driver to PNG, I get the expected results.
> any ideas on this ?
> thanks in advance!
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
