imagemap output mode no longer working with 4.10
Dylan Beaudette
dylan.beaudette at GMAIL.COM
Tue Oct 17 17:19:19 EDT 2006
Hi David,
So far I have only noticed this behavior in phpMapscript. I will test it out
with CGI mode ASAP.
cheers,
Dylan
On Tuesday 17 October 2006 12:46, Fawcett, David wrote:
> Dylan,
> Do you see this behavior in 4.10 CGI, or just in phpMapScript 4.10.
> David.
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Dylan Beaudette
> Sent: Tuesday, October 17, 2006 1:39 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] imagemap output mode no longer
> working with 4.10
> Thank Steve.
> If there are any diagnostics I can perform to help nail down the culprit
> please let me know. The short explanation: with 4.8.x imagemap output
> works
> as expected and documented. As of 4.10 there is an empty imagemap
> returned.
> Cheers,
> PS: is there a handy link to the bugtracker near?
> Dylan
> On Monday 16 October 2006 16:45, Steve Lime wrote:
> > You'll have to file a bug for this. There was a benign patch applied
> > in 4.10 that could be the culprit but we'd more information of
> > before/after output to be sure.
> > Steve
> > >>> Dylan Beaudette <dylan.beaudette at GMAIL.COM> 10/12/2006 7:36:59 PM
> > Hi,
> > I have been using the imagemap output driver since mapserver 4.6
> > without issue. Today, after updating to 4.10 I notice that the only
> > result from a
> > mapfile, rendered with phpmapscript, and using the imagemap output
> > driver is:
> > <map name="map1" width="450" height="500">
> > </map>
> > if i switch the output driver to PNG, I get the expected results.
> > any ideas on this ?
> > thanks in advance!
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
