Help with rasters
Jeff Dege
jdege at KORTERRA.COM
Fri Oct 20 14:24:20 EDT 2006
I've been trying to do the same, but the shp2img that came with ms4w
won't output TIFF files.
> -----Original Message-----
> From: Brent Pedersen [mailto:bpederse at nature.Berkeley.EDU]
> Sent: Friday, October 20, 2006 12:38 PM
> To: Jeff Dege
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Help with rasters
> hi, i just did something similar with a bunch of MrSID imagery,
> i got a bunch of help from #gdal,
> i generated a 15K * 15K pixel (.tiff) overview using shp2img,
> then (after gdaladdo) used that for large scales in the .map file
> and only resort to the MrSIDs when zoomed in pretty far.
> by the way, i think it took > 1 hour to generate the 15K by 15K
> pixel overview. but once it's done...
> -brent
> On Fri, 20 Oct 2006, Jeff Dege wrote:
> > Yep. That did it. I know have an image of the full extent
> of the map.
> > Only problem is that it took ten minutes to generate.
> > Next? Read up on optimization and tuning of raster maps.
> > Thanks for the help.
> >> From: Bart van den Eijnden (OSGIS) [mailto:bartvde at osgis.nl]
> >> Sent: Friday, October 20, 2006 11:49 AM
> >> To: Jeff Dege
> >> First of all, change:
> >> DATA "rasterindex"
> >> into:
> >> TILEINDEX "rasterindex"
> >> Best regards,
> >> Bart
> >> Jeff Dege schreef:
> >>> A customer has sent us a bunch of mapdata, to see if we
> can make any
> >>> sense from it. I've been messing around with mapserver
> for a while,
> >>> now, and I've figured out how to work some of its
> >> capabilities, but this
> >>> is my first attempt to handle rasters.
> >>> The data set has four sets of shape files, three of which are
> >>> point/line/polygon data and the fourth which seems to be a
> >> tileindex for
> >>> the thousands of jpg and jgw files.
> >>> I'm starting simple - writing a map file and trying to get
> >> a map image
> >>> using shp2img. I have no problem doing this with the three
> >>> point/line/polygon layers. But I've not been able to do
> >> this with the
> >>> raster data.
> >>> I can run gdalinfo on the jpg files:
> >>> Driver: JPEG/JPEG JFIF
> >>> Size is 1610, 1609
> >>> Coordinate System is `'
> >>> Origin = (-93.112361,44.933805)
> >>> Pixel Size = (0.00001279,-0.00000900)
> >>> Corner Coordinates:
> >>> Upper Left ( -93.1123608, 44.9338046)
> >>> Lower Left ( -93.1123608, 44.9193245)
> >>> Upper Right ( -93.0917678, 44.9338046)
> >>> Lower Right ( -93.0917678, 44.9193245)
> >>> Center ( -93.1020643, 44.9265646)
> >>> Band 1 Block=1610x1 Type=Byte, ColorInterp=Red
> >>> Band 2 Block=1610x1 Type=Byte, ColorInterp=Green
> >>> Band 3 Block=1610x1 Type=Byte, ColorInterp=Blue
> >>> I can run gdaltindex to create my own tileindex shape file:
> >>> gdaltindex \\server\share\test\data\rasterindex
> >>> And I can run ogrinfo on the generated shapefile:
> >>> INFO: Open of `\\server\share\app\data'
> >>> using driver `ESRI Shapefile' successful.
> >>> Layer name: rasterindex
> >>> Geometry: Polygon
> >>> Feature Count: 683
> >>> Extent: (-93.338884, 44.455961) - (-92.721094, 44.933805)
> >>> Layer SRS WKT:
> >>> (unknown)
> >>> location: String (255.0)
> >>> But when I run shp2img, I get nada. With DEBUG=ON:
> >>> Unable to open file rasterindex for layer A ... ignoring
> >> this missing
> >>> data.
> >>> msDrawMap(): Layer 0 (A), 0.000s
> >>> msDrawMap(): Drawing Label Cache, 0.000s
> >>> msDrawMap() total time: 0.000s
> >>> The rastedindex shape files (.dbf, .shp, and .shf) files
> >> are in the same
> >>> directories as the other point/line/polygon shape files
> >> that I've been
> >>> able to successfully draw layers with using this mapfile.
> >> Ogrinfo has
> >>> no trouble accessing the file.
> >>> The underlying .jpg files are in the same directory, and
> >> gdalinfo and
> >>> gdaltindex had no trouble opening them.
> >>> The layer in the mapfile itself is pretty simple:
> >>> LAYER
> >>> NAME "A"
> >>> TYPE RASTER
> >>> STATUS ON
> >>> DATA "rasterindex"
> >>> END
> >>> Any hints as to what I'm doing wrong?
> >> OSGIS, Open Source GIS
> >> bartvde at osgis.nl
> >> http://www.osgis.nl
