WMS images returned as Content-type: text/plain
Andrew Larcombe
andrew at ANDREWLARCOMBE.CO.UK
Fri Oct 20 19:06:54 EDT 2006
I've come across a wierd problem, namely my mapserver powered WMS is
returning Content-type: text/plain before the 'proper' Content-type for
the image. I'm pulling my hair out and it's getting late, so I'm asking
in the hope that someone else has been here and done this already.
Using wget to get a fairly straightforward WMS request:
>$ wget -S
"http://myserver/cgi-bin/srtm.wms?LAYERS=srtm&FORMAT=image/jpeg&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application/vnd.ogc.se_inimage&SRS=EPSG:4326&BBOX=-1.757812,50.656426,-1.40625,50.878777&WIDTH=256&HEIGHT=256"
--23:55:17--
`srtm.wms?LAYERS=srtm&FORMAT=image%2Fjpeg&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG:4326&BBOX=-1.757812,50.656426,-1.40625,50.878777&WIDTH=256&HEIGHT=256.6'
Resolving myserver... 111.222.333.444
Connecting to myserver|111.222.333.444|:80... connected.
HTTP request sent, awaiting response...
HTTP/1.1 200 OK
Date: Fri, 20 Oct 2006 22:54:32 GMT
Server: Apache/1.3.33 (Unix) PHP/5.0.3
Connection: close
Content-Type: text/plain
Length: unspecified [text/plain]
[ <=> ] 1,039 1.96K/s
23:55:18 (1.96 KB/s) -
saved [1039]
The Content-Type is returned as text/plain for some reason. Cat'ing the
file reveals that there's another Content-type:, followed by the line
feed, followed by the actual jpeg image. By removing the first two lines
in vi and saving the file, I'm able to view the jpeg just fine.
>$ cat
srtm.wms\?LAYERS\=srtm\&FORMAT\=image%2Fjpeg\&SERVICE\=WMS\&VERSION\=1.1.1\&REQUEST\=GetMap\&STYLES\=\&EXCEPTIONS\=application%2Fvnd.ogc.se_inimage\&SRS\=EPSG\:4326\&BBOX\=-1.757812\,50.656426\,-1.40625\,50.878777\&WIDTH\=256\&HEIGHT\=256.6
Content-type: image/jpeg
<load of binary content here, stripped for email>
I'm sure the answer is probably straightforward, but why/how is
mapserver adding the spurious Content-type header and screwing these
requests up?
Thanks,
Andrew
Andrew Larcombe
Freelance Geospatial, Database & Web Programming
web: http://www.andrewlarcombe.co.uk
email: andrew at andrewlarcombe.co.uk
icq: 306690163
