phpmapscript: changing a layer's style
Dylan Beaudette
dylan.beaudette at GMAIL.COM
Mon Oct 23 18:02:52 EDT 2006
Thanks for the tips,
however this does not *appear* to work for STYLE objects within a CLASS
object...
I have tried extracting the classObj and setting a parameter with:
class->set('outlinecolor', '100 100 100')
however this does not work.
dylan
On Monday 23 October 2006 03:16, Pietro Giannini wrote:
> Dylan,
> If you.re using mapserver as cgi you can change the mapfile parameters
> through a URL:
> http://mapserver.gis.umn.edu/docs/reference/cgi/controls (end of
> document: "Changing map file parameters via a form or a URL").
> Instead, via php and mapscript you can change the properties of the layer
> object via the method:
> $layer->set(property_name, new_value).
> ciao
> ___________________________
> Pietro Giannini
> Bytewise srl - Area GIS
> 41°50'38.58"N 12°29'13.39"E
> On Lun, 23 Ottobre 2006 6:47, Dylan Beaudette disse:
> > Greetings,
> > is there a simple way to change an existing layer's style?
> > so far i am able to change a layer's filter expression, etc. but not able
> > to
> > adjust the style defined in the first class.
> > any examples out there?
> > thanks in advance!
> > Dylan Beaudette
> > Soils and Biogeochemistry Graduate Group
> > University of California at Davis
> > 530.754.7341
Dylan Beaudette
530.754.7341
