phpmapscript: changing a layer's style
Dylan Beaudette
dylan.beaudette at GMAIL.COM
Mon Oct 23 19:27:24 EDT 2006
Thanks a lot aaron!
That did the trick, take a look at the results if you have a spare minute:
On Monday 23 October 2006 14:58, Aaron Racicot wrote:
> Hi there Dylan,
> Have not had the chance to say HI in a while... Great to see some GRASS
> guru's diving into Mapserver!
> You might already be doing something similar to this but:
> 1) You need to get the CLASS object
> 2) Then you need to get the STYLE object within that class using the
> following:
> styleObj getStyle(int index)
> Return the style object using an index. index >= 0 &&
> index < class->numstyles.
> 3) Then you can use the set method of the STYLE object for things other
> than color, but since colors are of type colorObj you need to set them
> directly using the setRGB method.
> Something like:
> $style = $class->getStyle(1);
> $style->color->setRGB($red,$green,$blue);
> $style->outlinecolor->setRGB(0,0,0);
> Check out the docs at:
> http://mapserver.gis.umn.edu/docs/reference/phpmapscript-class/classes/clas
>s obj
> http://mapserver.gis.umn.edu/docs/reference/phpmapscript-class/classes/styl
>e obj
> http://mapserver.gis.umn.edu/docs/reference/phpmapscript-class/classes/colo
>r obj
> Hope this helps.
> Aaron
> | Aaron Racicot | aaronr at ecotrust.org |
> | GIS Programmer | 360.221.2441 |
> | e c o t r u s t |
> | Jean Vollum Natural Capital Center |
> | 721 NW Ninth Avenue |
> | Suite 200 |
> | Portland, OR 97209 |
> | www.ecotrust.org |
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Dylan Beaudette
> Sent: Monday, October 23, 2006 3:03 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] phpmapscript: changing a layer's style
> Thanks for the tips,
> however this does not *appear* to work for STYLE objects within a CLASS
> object...
> I have tried extracting the classObj and setting a parameter with:
> class->set('outlinecolor', '100 100 100')
> however this does not work.
> dylan
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
