UMN + SDE
Pleyer, Walter Walter.Pleyer at LFRZ.AT
Wed Oct 25 10:25:24 EDT 2006
Hi folks!
It seems as if mapserver hast serious problems with layers SDE where
column names contain a '_' .
It displays all other layers, but if a column name contains '_' I get
this message:
"msDrawMap(): Image handling error. Failed to draw layer named 'test'.
msSDELayerInitItemInfo(): General error message. Item not found in SDE
table. "
Does anyone have experience with this problem and is there a workaround
(other than renaming all columns)?
Walter
LFRZ
A-1200 Wien, Dresdner Strasse 89
Tel:   ++43(1)33 176/421
Fax:   ++43(1)33 176/999
Mobil: 0676/5256642
Email: walter.pleyer at lfrz.at
WWW:   http://www.lfrz.at
