WMS GetFeatureInfo on joined PostGIS layer
James Perrins james.perrins at GMAIL.COM
Thu Oct 26 03:59:41 EDT 2006
This has got me stumped
mapserv481 (or 4.10)
Windows XP / IIS
PostGIS / PostGres 8.1
http://127.0.0.1/scripts/mapserv481.exe?map=C:/Inetpub/wwwroot/WMSServices/marine.map&SERVICE=WMS&SRS=EPSG:4326&VERSION=1.1.1&REQUEST=GetFeatureInfo&X=145&Y=84&QUERY_LAYERS=SurveyPoints&LAYERS=SurveyPoints&BBOX=-5.480804443359375,51.163844261348245,-4.519500732421875,51.76274043738508&WIDTH=700&HEIGHT=700
The above feature Info request works on a PostGIS single data layer
(full layer definition appended at end for info)
(e.g. DATA "the_geom from sample")
But the same request fails when I change the DATA to a joined table
(e.g. DATA "the_geom from (select sample.sample_key as id,
sample.the_geom, species.name as name from sample inner join species
on species.sample_key = sample.sample_key where species.name= 'Mytilus
edulis' ) as foo USING UNIQUE id using srid=4326")
Both data layers display data on the map OK – its just the
GetFeatureInfo that fails on the joined PostGIS layer with the
following error:
GetFeatureInfo results:
Layer 'SurveyPoints'
Content-type: application/vnd.ogc.se_xml
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://schemas.opengeospatial.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException>
</ServiceException>
</ServiceExceptionReport>
If no data is returned then it works OK (GetFeatureInfo results:
Search returned no results.)
–               so it must be something to do with how either I /
mapserver is failing to interpret / match the joined fields from the
data statement – but I just can't see it
I've also tried using a view in PostGreSQL:
SELECT foo.id, foo.sample_key, foo.the_geom, foo.name
   FROM ( SELECT species.taxon_key AS id, sample.sample_key,
           FROM sample
      JOIN species ON species.sample_key::text = sample.sample_key::text
     WHERE species.name::text = 'Mytilus edulis'::text) foo;
And - DATA "the_geom from mytilus USING UNIQUE id using srid=4326"
or DATA "the_geom from mytilus"
Both these display the data on a map OK – but produce the same error
with GetFeatureInfo
Anyone any ideas ?
Many Thanks
James
LAYER
   NAME "SurveyPoints"
            CONNECTION "user=gisdb password=gisdb dbname=gisdb
host=127.0.0.1 port=5432"
            CONNECTIONTYPE postgis
            #DATA "the_geom from mytilus USING UNIQUE id using srid=4326"
            #DATA "the_geom from (select sample.sample_key as id,
'%speciesname%' ) as foo USING UNIQUE id using srid=4326"
            #DATA "the_geom from (select species.taxon_key as id,
sample.sample_key, sample.the_geom, species.name as name from sample
inner join species on species.sample_key = sample.sample_key where
species.name= 'Mytilus edulis' ) as foo USING UNIQUE id using
srid=4326"
   #for WMS attributes
   TEMPLATE "marinetemplate.htm"
   DUMP true
   METADATA
            "wms_title"                    "SurveyPoints"
            "wms_srs"                     "EPSG:27700 EPSG:4326 EPSG:54004"
            "gml_include_items"      "all"
   END
   TYPE POINT
   PROJECTION
        "init=epsg:4326"
   END
   STATUS ON
   LABELITEM "id"
   LABELMAXSCALE 50000
   LABELMINSCALE 0
   LABELCACHE ON
   CLASS
    LABEL
       ANTIALIAS TRUE
       SIZE small
       POSITION AUTO
       OFFSET 1 1
       BUFFER 1
       COLOR 255 0 0
       OUTLINECOLOR 255 255 255
    END
    SYMBOL 'circle'
    SIZE 4
    OUTLINECOLOR 255 0 0
   END # end of class object
   TOLERANCE 100
END # end of layer object
mapserv481
Windows XP / IIS
following error:
<ServiceException>
</ServiceException>
           FROM sample
with GetFeatureInfo
Anyone any ideas ?
Many Thanks
James
LAYER
   NAME "SurveyPoints"
srid=4326"
   #for WMS attributes
   DUMP true
   METADATA
   END
   TYPE POINT
   PROJECTION
        "init=epsg:4326"
   END
   STATUS ON
   LABELITEM "id"
   LABELMAXSCALE 50000
   LABELMINSCALE 0
   LABELCACHE ON
   CLASS
    LABEL
       ANTIALIAS TRUE
       SIZE small
       POSITION AUTO
       OFFSET 1 1
       BUFFER 1
       COLOR 255 0 0
    END
    SYMBOL 'circle'
    SIZE 4
   TOLERANCE 100
