4.10 GEOS Fuctions with PHP Mapscipt
CamKhmer
chrisscrazydays at HOTMAIL.COM
Wed Oct 25 21:25:04 EDT 2006
Hi Steve,
Thanks for your response. I am not receiving the response I was expecting
from the shapeObj->within() method when I pass to it a shapeObj from a
separate layer. I was expecting that GEOS would compare the geometry of
shape A and shape B then determine whether one was within the other, if this
was the case I thought that this method could take any valid shape object
regardless of its source, but this appears not to be the case. Here's a
thinned down version of what I'm trying to do (apologies for posting an
elongated chunk of code up):
<?php
$oMap = ms_newMapObj($szMapFile);
function getShapeByName($oMap, $sLayerName, $sColumnName, $sShapeName){
$oLayer = $oMap->getLayerByName($sLayerName);
$oLayer->open();
//returns all the shapes in the layer
$status = $oLayer->whichShapes($oMap->extent);
//Loop through each of the shapes
while ($shape = $oLayer->nextShape())
$shapeIndex = $shape->index;
$oShape = $oLayer->getShape(-1,$shapeIndex);
$sName = $oShape->values[$sColumnName];
//return if we have the shape we're after
if($sName == $sShapeName) {
return $oShape;
return null;
//$oLayer->close();
//Get the province shape obj
$oProvShape = getShapeByName($oMap, 'provinces_fill', 'NAME','KHAMMUANE');
//Get the district shape obj
$oDistShape = getShapeByName($oMap, 'districts', 'NAME', 'NAKAI');
//This shows I have the shape object so we know there are no problems prior
to this
print_r($oProvShape);
print_r($oDistShape);
//See if one shape is within another
$inside = $oProvShape->within($oDistShape);
//Should return true or false
echo $inside;
The above code just returns a blank screen, if I replace:
with:
$inside = $oProvShape->within($oProvShape);
It returns 1 as expected, which indicated to me that shape objects from one
shape file can't be passed as an argument for the within() method of a shape
object from a different shape file. Is this the case? If so is there any
work around you can think of that doesn't involve dumping all the layers in
a single shape file.
Thanks for any input you can give me.
Chris
Steve Lime wrote:
> Chris: The GEOS operators work at the shapeObj level and have no
> connection to
> parent layers (you can create shapeObj's without mapfiles).
> Are you seeing strange behavior?
> Steve
>>>> CamKhmer <chrisscrazydays at HOTMAIL.COM> 10/24/2006 7:27:14 AM >>>
> Hi Guys,
> I have just begun experimenting with the GEOS functions now available in
> 4.10 via mapscript and have a question.
> Can shape objects from layer object A be passed as arguments to shape
> object
> methods in layer object B? (Each layer has a separate shape file)
> I am trying to create a function that determines if shape A (district) is
> within shape B (province), as stated above both layers are separate layers
> in separate shape files.
> I know I have the objects needed as both can be output using print_r(), I
> know the method is working as if I pass a shape object from the same layer
> I
> get the results as expected.
> Is it just the case that shape objects from different layers or shape
> files
> cant be passed as objects to shapeObj methods? If so it there any
> feasible
> way around this or am I just going to have to put both districts and
> provinces in the same layer and output them through class references?
> Thanks for your ideas,
> Chris
> http://www.nabble.com/4.10-GEOS-Fuctions-with-PHP-Mapscipt-tf2500940.html#a6971770
> Sent from the Mapserver - User mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/4.10-GEOS-Fuctions-with-PHP-Mapscipt-tf2500940.html#a7003645
