4.10 GEOS Fuctions with PHP Mapscipt
Yewondwossen Assefa assefa at DMSOLUTIONS.CA
Thu Oct 26 10:30:31 EDT 2006
Chris,
  The within function returns true or false so tests should be done like
this if ($oProvShape->within($oDistShape)) echo "1" else echo "0".  The
blank page in your case simple means that the within function returned
false.
  Is it possible that the test you are doing is inversed? : by looking
at the name of the layers, I am assuming that districts are inside
provinces so a call $oProvShape->within($oDistShape) would return false
and the $oDistShape->within($oProvShape); would return true.
  I have checked the documentation of php mapscript and it was stated
incorrectly leading to the confusion. It is now updated and reflects the
correct syntax.
  Let me know if that solves your problem.
Best Regards,
CamKhmer wrote:
> Hi Steve,
> Thanks for your response. I am not receiving the response I was expecting
> from the shapeObj->within() method when I pass to it a shapeObj from a
> separate layer. I was expecting that GEOS would compare the geometry of
> shape A and shape B then determine whether one was within the other, if this
> was the case I thought that this method could take any valid shape object
> regardless of its source, but this appears not to be the case. Here's a
> thinned down version of what I'm trying to do (apologies for posting an
> elongated chunk of code up):
> <?php
> $oMap = ms_newMapObj($szMapFile);
> function getShapeByName($oMap, $sLayerName, $sColumnName, $sShapeName){
> 	$oLayer = $oMap->getLayerByName($sLayerName);
> 	$oLayer->open();
> 	//returns all the shapes in the layer
> 	$status = $oLayer->whichShapes($oMap->extent);
> 	//Loop through each of the shapes
> 	while ($shape = $oLayer->nextShape())
> 			   $shapeIndex = $shape->index;
> 			   $oShape = $oLayer->getShape(-1,$shapeIndex);
> 			   $sName = $oShape->values[$sColumnName];
> 			   //return if we have the shape we're after
> 			   if($sName == $sShapeName) {
> 			   		return $oShape;
> 	return null;
> 	//$oLayer->close();
> //Get the province shape obj
> $oProvShape = getShapeByName($oMap, 'provinces_fill', 'NAME','KHAMMUANE');
> //Get the district shape obj
> $oDistShape = getShapeByName($oMap, 'districts', 'NAME', 'NAKAI');
> //This shows I have the shape object so we know there are no problems prior
> to this
> print_r($oProvShape);
> print_r($oDistShape);
> //See if one shape is within another
> $inside = $oProvShape->within($oDistShape);
> //Should return true or false
> echo $inside;
> The above code just returns a blank screen, if I replace:
> with:
> $inside = $oProvShape->within($oProvShape);
> It returns 1 as expected, which indicated to me that shape objects from one
> shape file can't be passed as an argument for the within() method of a shape
> object from a different shape file. Is this the case? If so is there any
> work around you can think of that doesn't involve dumping all the layers in
> a single shape file.
> Thanks for any input you can give me.
> Chris
> Steve Lime wrote:
>>Chris: The GEOS operators work at the shapeObj level and have no
>>connection to
>>parent layers (you can create shapeObj's without mapfiles).
>>Are you seeing strange behavior?
>>Steve
>>>>>CamKhmer <chrisscrazydays at HOTMAIL.COM> 10/24/2006 7:27:14 AM >>>
>>Hi Guys,
>>I have just begun experimenting with the GEOS functions now available in
>>4.10 via mapscript and have a question.
>>Can shape objects from layer object A be passed as arguments to shape
>>object
>>methods in layer object B? (Each layer has a separate shape file)
>>I am trying to create a function that determines if shape A (district) is
>>within shape B (province), as stated above both layers are separate layers
>>in separate shape files.
>>I know I have the objects needed as both can be output using print_r(), I
>>know the method is working as if I pass a shape object from the same layer
>>I
>>get the results as expected.
>>Is it just the case that shape objects from different layers or shape
>>files
>>can’t be passed as objects to shapeObj methods? If so it there any
>>feasible
>>way around this or am I just going to have to put both districts and
>>provinces in the same layer and output them through class references?
>>Thanks for your ideas,
>>Chris
>>View this message in context:
>>http://www.nabble.com/4.10-GEOS-Fuctions-with-PHP-Mapscipt-tf2500940.html#a6971770
>>Sent from the Mapserver - User mailing list archive at Nabble.com.
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
