freetype error for curved label
Steve Lime Steve.Lime at DNR.STATE.MN.US
Thu Oct 26 14:20:37 EDT 2006
The follow support requires a newish version of GD that provided
extended metrics from Freetype.
We can't test in configure for that function, but we can test for
another function that was added
in that version. The relevant test when you watch for configure is
looking for gdImageOpenPolygon.
If that's found you have enough for path following labels.
Basically you need gd 2.0.29+ but 2.0.33 is recommended.
Steve
>>> Stephen Woodbridge <woodbri at SWOODBRIDGE.COM> 10/26/2006 8:51:01 AM
What does "/path/to/mapserv -v" report?
-Steve W
Yves Jacolin wrote:
> Hi,
> I am trying to build mapserver 4.10 to use curved label. When I use
ANGLE
> FOLLOW parameter in my mapfile I got this error :
> "Mapserver error: Error in msDrawTextGD(): TrueType font support is
not
> available and is required for angled text rendering.
> Error in msDrawTextGD(): TrueType font support is not available and
is
> required for angled text rendering."
> But, I got freetype in mapserver config. No error message/warning. Do
you know
> where this problem come from ?
> My mapfile config :
> FONTSET fonts.txt
> And fonst.txt :
> Vera    ./vera/Vera.ttf
> VeraBd  ./vera/VeraBd.ttf
> Both url files are correct.
> Regards,
> Y.
