freetype error for curved label
Yves Jacolin
yjacolin at FREE.FR
Thu Oct 26 12:58:23 EDT 2006
Here the report :
./mapserv -v
MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_CLIENT SUPPORTS=GEOS INPUT=EPPL7
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
Actually, I am using php_mapscript on a mandriva linux with PHP5 in CGI mode.
Phpinfo tells me the same information.
$ freetype-config --version
9.8.3
Thanks,
Y.
Le Jeudi 26 Octobre 2006 15:51, Stephen Woodbridge a écrit :
> What does "/path/to/mapserv -v" report?
> -Steve W
> Yves Jacolin wrote:
> > Hi,
> > I am trying to build mapserver 4.10 to use curved label. When I use ANGLE
> > FOLLOW parameter in my mapfile I got this error :
> > "Mapserver error: Error in msDrawTextGD(): TrueType font support is not
> > available and is required for angled text rendering.
> > Error in msDrawTextGD(): TrueType font support is not available and is
> > required for angled text rendering."
> > But, I got freetype in mapserver config. No error message/warning. Do you
> > know where this problem come from ?
> > My mapfile config :
> > FONTSET fonts.txt
> > And fonst.txt :
> > Vera ./vera/Vera.ttf
> > VeraBd ./vera/VeraBd.ttf
> > Both url files are correct.
> > Regards,
> > Y.
Yves Jacolin
HBS-Research
51 rue de Verdun
92 158 Suresnes CEDEX
Tél. : 01 46 97 25 14
Fax : 01 46 97 20 10
Yves Jacolin
http://yjacolin.gloobe.org
