Using multiple .dbf files with the same .shp/.shx files
Till Adams
adams at TERRESTRIS.DE
Sun Oct 29 09:00:56 EST 2006
Matt,
I guess it is difficult to do what you want. A shapefile is handled as one
file, although there are always three files.
Maybe it's possible for you to workaround with that JOIN Object in the
mapfile.
http://mapserver.gis.umn.edu/docs/reference/mapfile/join/?searchterm=JOIN
Or you store the shapestuff in a database (or you create three shapes with
different namens and dbf-files). Then you may use the Variable
Substitution functionality from mapserver and pass the filename via the
url when requesting the map.
Till :-)
> Is there any way to use different .dbf files with the same .shp/.shx
> file in MapServer? I'd like to make an online application that, based
> on some choices, would pull info from a different .dbf file, but use the
> same .shp/.shx file. The different requests would have different .map
> files, but I don't see if there is any way to identify a different .dbf
> file to use other than the one of the same basename as the .shp/.shx
> files...
> Thanks,
> Matt
* released: AmeiN! ArcMap-Export-2-UMN *
* LiveLinux 'WebGIS on CD' *
* http://www.terrestris.de *
Dipl. Geogr. Till Adams
terrestris, H. Paulsen& T. Adams GbR
Siemensstr. 8 * 53121 Bonn
Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57 info at terrestris.de *
