php_mapscript on IIS6/WinServer2003
Rafael Szajbel
szajbel at WIDEMANN.DE
Mon Oct 30 03:31:34 EST 2006
Hi Jin,
the others dll's from php_mapserver_4.8.1-win32-php5.1.2.zip are also needed.
You can open the php_mapscript_48.dll with the program "Dependency Walker" and then you see which dll fails.
Using of php_mapscript_48.dll is also impossible, when older versions of the dll's are located in the folder C:\Windows\System32 for example.
Best regards
Rafael
----- Original Message -----
To: MAPSERVER-USERS at LISTS.UMN.EDU
Sent: Friday, October 27, 2006 9:37 PM
Subject: [UMN_MAPSERVER-USERS] php_mapscript on IIS6/WinServer2003
Hello All,
I set up a new Windows Server 2003 Web Edition with SP1, downloaded PHP 5.1.6 for win32 binary, configured successfully and I am able to run phpinfo.php to test.
Then I downloaded php_mapserver_4.8.1-win32-php5.1.2 binary. I don't need the map server, all I want is to install php_mapscript, so I just copy php_mapscript_48.dll to all possible directories (c:\php, c:\php\ext, c:\windows\system32). configure c:\windows\php.ini to use extension=php_mapscript_48.dll.
I changed phpinfo.php as below,
<?php
dl("php_mapscript_48.dll");
phpinfo();
I can still run it. But the output is not different from the old phpinf which has no dl("php_mapscript_48.dll");
Then I copied my map program from another computer with differnt configuration : Win2000 Server, php4, php_mapscript_35.dll. The program works ine on that computer but does NOT work on this computer.
The script is like below,
$shapeFile = ms_newShapeFileObj( "thefilename", MS_SHP_POINT);
Because the script has been working on the old computer for years, I don't think it is the problem of the script. Probably it is the installation of php_mapscript. On Win2000, the .php extension is set to use c:\php\php.exe, on Win2003, I tried to set it to C:\php\php5isapi.dll and php.exe.
Is there anybody who has the same configuration (W2K3, IIS, PHP5, Mapscript) and got it work? Any advice?
Thanks.
Jin
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061030/b68c0eae/attachment.html
