[Fwd: Re: [UMN_MAPSERVER-USERS] CLASS and php/mapscript]
Pietro Giannini
pgiannini at BYTEWISE.IT
Mon Oct 30 11:35:00 EST 2006
Bug #1951 submitted.
___________________________
Pietro Giannini
Bytewise srl - Area GIS
41°50'38.58"N 12°29'13.39"E
On Lun, 30 Ottobre 2006 16:21, Stephen Woodbridge disse:
> Please write a bug against this for mapscript.
> It might end up being a doc bug but setting the color -1,-1,-1 means to
> make the object transparent. For example you would use this for the
> color of a polygon to make it transparent and then could set the border
> to black to highlight the edge of the polygon with out over writing the
> actual polygon.
> -Steve W
> Pietro Giannini wrote:
>> Sorry for previous incomplete message
>> Luca,
>> I discovered that when tou set
>> $style->color->setRGB( -1,-1,-1);
>> nothing appears,
>> instead if you set
>> $style->color->setRGB(0,0,0);
>> works!
>> Evidently MS does not consider a valid color the RGB( -1,-1,-1), only a
>> mapfile annotation, and does not save it when invoking $map->save().
>> ciao
>> PG
>> Pietro Giannini
>> On Lun, 30 Ottobre 2006 13:10, Luca Casagrande disse:
>>> Hi Pietro and thx for your answer!
>>> This is the code i use for creating the new class:
>>> $class = ms_newClassObj($layer);
>>> $class->setExpression("'[pixel]' EQ '1'");
>>> $style = ms_newStyleObj($class);
>>> $style=$class->getStyle(0);
>>> And this is the debug mapfile:
>>> CLASS
>>> EXPRESSION "'[pixel]' EQ '1'"
>>> METADATA
>>> END
>>> STYLE
>>> ANGLE 360
>>> SYMBOL 0
>>> END
>>> END
>>> What i am doing wrong?
>>> Thanks
>>> Luca
>>> On Mon, 30 Oct 2006 12:53:42 +0100
>>> Pietro Giannini <pgiannini at BYTEWISE.IT> wrote:
>>>> Luca,
>>>> I had a similar problem.
>>>> Try:
>>>> In other words you must get the reference of the existing Style from
>> the Class.
>>>> I made so, and works... - I don't know because :) -
>>>> ciao
>>>> Pietro Giannini
>>>> On Lun, 30 Ottobre 2006 12:03, Luca Casagrande disse:
>>>>> Hi to all!
>>>>> I am trying to create a new layer using php/mapscript; the problem is
>>>> for
>>>>> the class section:
>>>>> this is the mapfile sample i'd like to crete:
>>>>> CLASS
>>>>> EXPRESSION "1"
>>>>> STYLE
>>>>> COLOR -1 -1 -1
>>>>> END
>>>>> END
>>>>> And this is the mapscript i have written:
>>>>> Debugging the mapfile, the CLASS it's been created, but not the style
>>>> of
>>>>> the class.
>>>>> Thanks very much
>>>>> Luca
>>>>> Help QGIS development! Make a donation right now at
>>>>> http://xrl.us/supportqgis
>>>>> LINUX User #411601
>>>>> GENTOO-GIS Development Team
>>>>> jabber: casagrande at jabber.linux.it
>>> LINUX User #411601
>> Pietro Giannini
