Limiting the viewable extent...
Bob Basques
bob.basques at CI.STPAUL.MN.US
Tue Oct 31 12:54:35 EST 2006
All,
One method you might try, would be to use the new include mechanisms in
the MAPFILES and have a separate MapFile header for each client. You
need to set the Extents somewhere anyway, just keep a separate header
file and include the LAYER defs from a separate central file.
Although, this is not full proof with regard to locking folks out if
they now the names of the MAPFILE headers for requesting.
bobb
Stephen Woodbridge wrote:
> Steve,
> I may be confusing this with a feature of ka-map, but I'm not sure.
> Steve L do you know if there is such a feature in mapserver?
> -Steve W
> ps: lots of Steve is confusing!
>>> Steve Hall wrote:
>>>> Hi all,
>>>> Is it possible to restrict the users viewable extent of the map
>>>> through the map file? For example, I have data loaded for the whole
>>>> of the country but I want it to be impossible for any client tool to
>>>> view data beyond a defined and fixed extent.
>>>> The EXTENT parameters just seem to set the initial extent and you can
>>>> easily zoom out beyond this extent.
>>>> I appreciate this is fairly easy to do through code but though that
>>>> if this was possible via a mapfile then it would be done at the
>>>> 'lowest' level...
>>> Yes, I believe you can do it by setting METADATA values for the MAP
>>> object. I just check the mapfile reference and it is not described
>>> there. Could you please write a documentation bug to request all
>>> METADATA controls be documented.
>>> -Steve W.
>> Thanks for this Steve, do you happen to know off hand any of the
>> relevant keywords to this problem (to get me started). I could take a
>> look through the code and dig deeper if I have somewhere to start.
>> This will also enable me to file a more accurate and useful bug...
>> Cheers,
>> Steve H
**************** You can't be late until you show up. ***************
************ You never learn anything by doing it right. ************
*** War doesn't determine who's right. War determines who's left. ***
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061031/fa1356ee/bob.basques.vcf
