Limiting the viewable extent...
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Tue Oct 31 12:47:06 EST 2006
Steve,
I may be confusing this with a feature of ka-map, but I'm not sure.
Steve L do you know if there is such a feature in mapserver?
-Steve W
ps: lots of Steve is confusing!
Steve Hall wrote:
> Stephen Woodbridge wrote:
>> Steve Hall wrote:
>>> Hi all,
>>> Is it possible to restrict the users viewable extent of the map
>>> through the map file? For example, I have data loaded for the whole
>>> of the country but I want it to be impossible for any client tool to
>>> view data beyond a defined and fixed extent.
>>> The EXTENT parameters just seem to set the initial extent and you can
>>> easily zoom out beyond this extent.
>>> I appreciate this is fairly easy to do through code but though that
>>> if this was possible via a mapfile then it would be done at the
>>> 'lowest' level...
>> Yes, I believe you can do it by setting METADATA values for the MAP
>> object. I just check the mapfile reference and it is not described
>> there. Could you please write a documentation bug to request all
>> METADATA controls be documented.
>> -Steve W.
> Thanks for this Steve, do you happen to know off hand any of the
> relevant keywords to this problem (to get me started). I could take a
> look through the code and dig deeper if I have somewhere to start.
> This will also enable me to file a more accurate and useful bug...
> Cheers,
> Steve H
