Java Mapscript with Japanese Encoding
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Fri Sep 1 06:39:29 EDT 2006
Mario,
the attached patch will make ms print on stdio the search string that
has reached the C-layer of mapserver. Output is verbose.
It should help you debug where the problem lies.
Regards,
Umberto
On 9/1/06, Mario Basa <mario.basa at gmail.com> wrote:
> Umberto,
> Thanks for the offer. I was really thinking of sending data for
> testing the other day, but it occured to me that your environment
> might not be capable of handling double-byte kanji characters.
> I guess we'll test QueryByAttributeUnicode from here.
> Mario.
> On 9/1/06, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> > Mario,
> > if you send me a sample shapefile, map and search string to test
> > against QueryByAttributeUnicode I'm willing to look into this.
> > Also, file an issue to bugzilla.
> > Umberto
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060901/ed78f5b0/basa-kanjii-dbg.bin
