Java Mapscript with Japanese Encoding
Mario Basa mario.basa at GMAIL.COM
Thu Sep 7 06:55:25 EDT 2006
Umberto,
I finally got it to work now with Shift-JIS. It turns out that there
was something wrong with my environment (to get sjis recognized in
RHEL4, see this
http://www.mland.jp/~fedora/mlbbs/mlbbs.cgi?mode=res&mo=34&namber=34&space=0&page=0&no=0
Attached is a screenshot of QueryByAttribute sample application using
Kanji characters. It is kind of awkward to change LANG environment for
each encoding, but it works.
Thanks.
Mario.
On 9/1/06, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> Mario,
> the attached patch will make ms print on stdio the search string that
> has reached the C-layer of mapserver. Output is verbose.
> It should help you debug where the problem lies.
> Regards,
> Umberto
> On 9/1/06, Mario Basa <mario.basa at gmail.com> wrote:
> > Umberto,
> > Thanks for the offer. I was really thinking of sending data for
> > testing the other day, but it occured to me that your environment
> > might not be capable of handling double-byte kanji characters.
> > I guess we'll test QueryByAttributeUnicode from here.
> > Mario.
> > > Mario,
> > > if you send me a sample shapefile, map and search string to test
> > > against QueryByAttributeUnicode I'm willing to look into this.
> > > Also, file an issue to bugzilla.
> > > Umberto
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060907/eecf89c7/mapscript-sjis.png
