Java Mapscript with Japanese Encoding
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Thu Sep 7 08:44:01 EDT 2006
Excellent!
Umberto
On 9/7/06, Mario Basa <mario.basa at gmail.com> wrote:
> Umberto,
> I finally got it to work now with Shift-JIS. It turns out that there
> was something wrong with my environment (to get sjis recognized in
> RHEL4, see this
> http://www.mland.jp/~fedora/mlbbs/mlbbs.cgi?mode=res&mo=34&namber=34&space=0&page=0&no=0
> Attached is a screenshot of QueryByAttribute sample application using
> Kanji characters. It is kind of awkward to change LANG environment for
> each encoding, but it works.
> Thanks.
> Mario.
> On 9/1/06, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> > Mario,
> > the attached patch will make ms print on stdio the search string that
> > has reached the C-layer of mapserver. Output is verbose.
> > It should help you debug where the problem lies.
> > Regards,
> > Umberto
> > On 9/1/06, Mario Basa <mario.basa at gmail.com> wrote:
> > > Umberto,
> > > Thanks for the offer. I was really thinking of sending data for
> > > testing the other day, but it occured to me that your environment
> > > might not be capable of handling double-byte kanji characters.
> > > I guess we'll test QueryByAttributeUnicode from here.
> > > Mario.
> > > > Mario,
> > > > if you send me a sample shapefile, map and search string to test
> > > > against QueryByAttributeUnicode I'm willing to look into this.
> > > > Also, file an issue to bugzilla.
> > > > Umberto
