PHP Mapscript and WMS Server
Frank Warmerdam warmerdam at POBOX.COM
Mon Sep 4 14:54:36 EDT 2006
Nicol Hermann wrote:
> Frank,
> thank you very much for your mail.
> I'm afraid there is still a problem somewhere.
> I checked out the latest cvs release and rerun my test script but the
> "bad lines" at the end are still present. PHP mapscript version is:
> $Id: php_mapscript.c,v 1.259 2006/08/31 15:34:30 assefa Exp $
> Is there's something i could do to further debug this issues?
> Maybe an other issue.
> I put together a simple wms server map-file which includes an other wms
> (demis). When i execute my PHP script with
> http://localhost/~nicol/mapserver/dev/wxsGetMapCascading.php?REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&LAYERS=Countries&WIDTH=200&HEIGHT=200&FORMAT=image/png&SRS=EPSG:4326&BBOX=5.86629,47.2736,15.0486,55.0583
> the Content-type won't be set correct.
Nicole,
I stand corrected.  The problem you are seeing is different than what I
thought was going on.  When I run your php script at the unix commandline
I get the following back:
Content-type: text/html
X-Powered-By: PHP/4.3.8
ttt9Content-type: image/png
?PNG
So the problem seems to be that PHP always emits the text/html content
type.  I don't know how to alter this in PHP, or even if it is possible.
But the problem is related to PHP document processing, not mapserver or
PHP Mapscript itself.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
