configuring WMS service
Eijnden, Bart van den (AGI) b.vdeijnden at AGI.RWS.MINVENW.NL
Wed Sep 6 04:32:12 EDT 2006
Which Mapserver version?
Can you post your complete MAP file, most specifically what is the name of your MAP object?
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens toni hernández
Verzonden: woensdag 6 september 2006 8:47
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] configuring WMS service
HI all,
I've reading the documentation about configuring a mapserver as a WMS
server.
Everything seems to be working fine except for the fact that the LAYERS
parameter (in the url) is not working properly.
In the map file I just have two layers: salt (.dgn file), and girona
(.shp file with poligons) . Both with status off in the map file
The problem is that the girona layer is always on the image. As you can
see in the URL bellow the layers parameter is just asking for the salt
layer.
http://sigserver4.udg.es/cgi-bin/salt_carto?request=GetMap&VERSION=1.1.0&SERVICE=WMS&SRS=EPSG:23031&BBOX=482840.46367545397,4646726.721942619,484238.53218965203,4648124.7904568175&WIDTH=600&HEIGHT=600&LAYERS=salt&STYLES=&FORMAT=image/gif&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&EXCEPTION=INIMAGE
Here is the girona layer in the map file.
LAYER
    NAME "girona"
    STATUS ON
    TYPE POLYGON
    DATA base
    MINSCALE 2600
    METADATA
          WMS_TITLE "Base Girona"
          WMS_SRS "EPSG:23031"
    END
    PROJECTION
        "init=epsg:23031"
    END
    CLASS
        NAME "Girona"
        OUTLINECOLOR 128 128 128
        COLOR 225 225 185
    END
END
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
