configuring WMS service
toni hernández
toni at SIGTE.UDG.ES
Wed Sep 6 04:48:39 EDT 2006
the version is 4.8.4
I have just seen that the name of the map object is the same of a layer.
Could that be a problem.
here goes the map file.
MAP
NAME SALT
STATUS ON
SIZE 500 300
EXTENT 481843.62 4644280.84 487294.27 4651758.01
UNITS METERS
SHAPEPATH "data"
IMAGECOLOR 255 255 255
# you may need to change this to match your MapServer build
IMAGETYPE PNG
PROJECTION
"init=epsg:23031"
END
# Start of web interface definition (including WMS enabling metadata)
WEB
TEMPLATE demo.html
MINSCALE 100
MAXSCALE 1550000
IMAGEPATH "/var/www/tmp/"
IMAGEURL "/tmp/"
METADATA
WMS_TITLE "SALT"
WMS_ABSTRACT "Servir la cartografia DGN de Salt"
WMS_ACCESSCONSTRAINTS "none"
WMS_ONLINERESOURCE "http://sigserver4.udg.es/mapserversalt"
WMS_SRS "EPSG:23031"
END
END
REFERENCE
IMAGE graphics/reference.gif
EXTENT 481144.82 4643861.56 489320.80 4651897.77
SIZE 150 150
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
QUERYMAP
SIZE 400 400
STATUS ON
STYLE HILITE
COLOR 255 0 0
END
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
IMAGECOLOR 0 0 0
LABEL
COLOR 255 255 255
SIZE TINY
END
STYLE 1
SIZE 100 2
COLOR 255 255 255
UNITS MILES
INTERVALS 1
TRANSPARENT TRUE
STATUS ON
END
# Start of symbol definitions (we're only using a few)
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
# Start of layer definitions
LAYER
NAME "girona"
STATUS ON
TYPE POLYGON
DATA base
MINSCALE 2600
METADATA
WMS_TITLE "Base Girona"
END
PROJECTION
"init=epsg:23031"
END
CLASS
NAME "Girona"
OUTLINECOLOR 128 128 128
COLOR 225 225 185
END
END
LAYER
NAME "salt"
STATUS ON
GROUP DGN
CONNECTIONTYPE OGR
TRANSPARENCY 100
CONNECTION "/var/www/mapserversalt/data/Saltcadv81.dgn"
TYPE line
TOLERANCE 10
STYLEITEM "AUTO"
METADATA
WMS_TITLE "Comerços"
END
PROJECTION
"init=epsg:23031"
END
CLASS
NAME "Salt"
color 255 0 255
END
#DUMP true
END
END # Map File
Eijnden, Bart van den (AGI) wrote:
> Which Mapserver version?
> Can you post your complete MAP file, most specifically what is the name of your MAP object?
> Best regards,
> Bart
> -----Oorspronkelijk bericht-----
> Van: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens toni hernández
> Verzonden: woensdag 6 september 2006 8:47
> Aan: MAPSERVER-USERS at LISTS.UMN.EDU
> Onderwerp: [UMN_MAPSERVER-USERS] configuring WMS service
> HI all,
> I've reading the documentation about configuring a mapserver as a WMS
> server.
> Everything seems to be working fine except for the fact that the LAYERS
> parameter (in the url) is not working properly.
> In the map file I just have two layers: salt (.dgn file), and girona
> (.shp file with poligons) . Both with status off in the map file
> The problem is that the girona layer is always on the image. As you can
> see in the URL bellow the layers parameter is just asking for the salt
> layer.
> http://sigserver4.udg.es/cgi-bin/salt_carto?request=GetMap&VERSION=1.1.0&SERVICE=WMS&SRS=EPSG:23031&BBOX=482840.46367545397,4646726.721942619,484238.53218965203,4648124.7904568175&WIDTH=600&HEIGHT=600&LAYERS=salt&STYLES=&FORMAT=image/gif&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&EXCEPTION=INIMAGE
> Here is the girona layer in the map file.
> LAYER
> NAME "girona"
> STATUS ON
> TYPE POLYGON
> DATA base
> MINSCALE 2600
> METADATA
> END
> PROJECTION
> "init=epsg:23031"
> END
> CLASS
> NAME "Girona"
> COLOR 225 225 185
> END
> END
> Disclaimer
> Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
> uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
> hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
> informeren. Wij adviseren u om bij twijfel over de juistheid of de
> volledigheid van de mail contact met afzender op te nemen.
> This message shall not constitute any rights or obligations.
> This message is intended solely for the addressee.
> If you have received this message in error, please delete it and
> notify the sender immediately. When in doubt whether this message
> is correct or complete, please contact the sender.
