configuring WMS service
toni hernández toni at SIGTE.UDG.ES
Wed Sep 6 04:55:11 EDT 2006
yeah!
I changed the map object name and now everything is working fine.
thanks a lot guys
toni hernández wrote:
> Hi,
> the version is 4.8.4
> I have just seen that the name of the map object is the same of a layer.
> Could that be a problem.
> here goes the map file.
> MAP
> NAME SALT
> STATUS ON
> SIZE 500 300
> EXTENT 481843.62 4644280.84 487294.27 4651758.01
> UNITS METERS
> SHAPEPATH "data"
> IMAGECOLOR 255 255 255
> # you may need to change this to match your MapServer build
> IMAGETYPE PNG
> PROJECTION
>  "init=epsg:23031"
> END
> # Start of web interface definition (including WMS enabling metadata)
>    WEB
>      TEMPLATE demo.html
>      MINSCALE 100
>      MAXSCALE 1550000
>      IMAGEPATH "/var/www/tmp/"
>      IMAGEURL "/tmp/"
>      METADATA
>          WMS_TITLE "SALT"
>          WMS_ABSTRACT "Servir la cartografia DGN de Salt"
>          WMS_ACCESSCONSTRAINTS "none"
>          WMS_ONLINERESOURCE "http://sigserver4.udg.es/mapserversalt"
>          WMS_SRS "EPSG:23031"
>      END
>    END
>    REFERENCE
>      IMAGE graphics/reference.gif
>      EXTENT 481144.82 4643861.56 489320.80 4651897.77
>      SIZE 150 150
>      STATUS ON
>      COLOR -1 -1 -1
>      OUTLINECOLOR 255 0 0
>    END
>    QUERYMAP
>      SIZE 400 400
>      STATUS ON
>      STYLE HILITE
>      COLOR 255 0 0
>    END
>    LEGEND
>      KEYSIZE 18 12
>      LABEL
>        TYPE BITMAP
>        SIZE MEDIUM
>        COLOR 0 0 89
>      END
>      STATUS ON
>    END
> # Start of scalebar
>  SCALEBAR
>    IMAGECOLOR 0 0 0
>    LABEL
>      COLOR 255 255 255
>      SIZE TINY
>    END
>    STYLE 1
>    SIZE 100 2
>    COLOR 255 255 255
>    UNITS MILES
>    INTERVALS 1
>    TRANSPARENT TRUE
>    STATUS ON
>  END
> # Start of symbol definitions (we're only using a few)
>    SYMBOL
>      NAME 'circle'
>      TYPE ELLIPSE
>      POINTS 1 1 END
>      FILLED TRUE
>    END
> # Start of layer definitions
> LAYER
>    NAME "girona"
>    STATUS ON
>    TYPE POLYGON
>    DATA base
>    MINSCALE 2600
>    METADATA
>          WMS_TITLE "Base Girona"
>    END
>    PROJECTION
>        "init=epsg:23031"
>    END
>    CLASS
>        NAME "Girona"
>        OUTLINECOLOR 128 128 128
>        COLOR 225 225 185
>    END
> END
> LAYER
>    NAME "salt"
>    STATUS ON
>    GROUP DGN
>    CONNECTIONTYPE OGR
>    TRANSPARENCY 100
>    CONNECTION "/var/www/mapserversalt/data/Saltcadv81.dgn"
>    TYPE line
>    TOLERANCE 10
>    STYLEITEM "AUTO"
>    METADATA
>          WMS_TITLE "Comerços"
>    END
>    PROJECTION
>        "init=epsg:23031"
>    END
>    CLASS
>        NAME "Salt"
>        color 255 0 255
>    END
>    #DUMP true
> END
> END # Map File
> Eijnden, Bart van den (AGI) wrote:
>> Which Mapserver version?
>> Can you post your complete MAP file, most specifically what is the
>> name of your MAP object?
>> Best regards,
>> Bart
>> -----Oorspronkelijk bericht-----
>> Van: UMN MapServer Users List
>> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens toni hernández
>> Verzonden: woensdag 6 september 2006 8:47
>> Aan: MAPSERVER-USERS at LISTS.UMN.EDU
>> Onderwerp: [UMN_MAPSERVER-USERS] configuring WMS service
>> HI all,
>> I've reading the documentation about configuring a mapserver as a WMS
>> server.
>> Everything seems to be working fine except for the fact that the
>> LAYERS parameter (in the url) is not working properly.
>> In the map file I just have two layers: salt (.dgn file), and girona
>> (.shp file with poligons) . Both with status off in the map file
>> The problem is that the girona layer is always on the image. As you
>> can see in the URL bellow the layers parameter is just asking for the
>> salt layer.
>> http://sigserver4.udg.es/cgi-bin/salt_carto?request=GetMap&VERSION=1.1.0&SERVICE=WMS&SRS=EPSG:23031&BBOX=482840.46367545397,4646726.721942619,484238.53218965203,4648124.7904568175&WIDTH=600&HEIGHT=600&LAYERS=salt&STYLES=&FORMAT=image/gif&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&EXCEPTION=INIMAGE
>> Here is the girona layer in the map file.
>> LAYER
>>     NAME "girona"
>>     STATUS ON
>>     TYPE POLYGON
>>     DATA base
>>     MINSCALE 2600
>>     METADATA
>>     END
>>     PROJECTION
>>         "init=epsg:23031"
>>     END
>>     CLASS
>>         NAME "Girona"
>>         COLOR 225 225 185
>>     END
>> END
>> Disclaimer
>> Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
>> uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
>> hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
>> informeren. Wij adviseren u om bij twijfel over de juistheid of de
>> volledigheid van de mail contact met afzender op te nemen.
>> This message shall not constitute any rights or obligations.
>> This message is intended solely for the addressee.
>> If you have received this message in error, please delete it and
>> notify the sender immediately. When in doubt whether this message
>> is correct or complete, please contact the sender.
