MapServer Capabilities
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Fri Sep 8 08:38:43 EDT 2006
Campbell, Keith A wrote:
> Thanks Steve.
> Does that mean that any layer based on a SQL Server DB (an ordinary
> layer without a join) would be relatively slow?
I believe only postgis has spatial indexes. You would need to read the
docs on OGR, it provides an ODBC connection that is basicaly used to
support dynamic data as a layer. It also has basic support for JOINs
between shapefiles and a database. I think this will suffer from poor
performance if you have a large dataset.
> Is it possible to create feature joins as I've described with other DB
> types?
Yes, if the database supports ODBC, but all the same problems will exist.
Only PostGIS/postgres have good native support built into mapserver and
a robust support gor geometry built into the database.
-Steve W
> Keith
> -----Original Message-----
> From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
> Sent: 08 September 2006 01:25
> To: Campbell, Keith A
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] MapServer Capabilities
>> I wish to establish the capabilities of MapServer as regards feature
>> joins. What I would like to do is create a map that has a number of
>> layers based on SHP file data. The display of the entities within the
>> SHP files needs to be themed based on attribute data held in a SQL
>> Server database. So the Feature ID of an object in the SHP file has a
>> corresponding ID in a record in the DB. Is this possible with
> MapServer?
>> If so, how difficult is it?
> You might be able to do this with GDAL/OGR, but it will not be fast. The
> ideal way to do this is to use postGIS to store the geometry and
> attributes, then you can do this easily and it will be fast.
> -Steve W.
> This message has been scanned for viruses by MailControl - (see
> http://bluepages.wsatkins.co.uk/?4318150)
> This email and any attached files are confidential and copyright protected. If you are not the addressee, any dissemination of this communication is strictly prohibited. Unless otherwise expressly agreed in writing, nothing stated in this communication shall be legally binding.
