Displaying LABEL with an ANGLE column value
Julian Parker julian at MAPSOLUTIONS.COM.AU
Mon Sep 11 02:05:45 EDT 2006
No sooner than I send the question I stumble across the solution. I had
been overlooking LABELANGLEITEM the whole time.
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Julian Parker
Sent: Monday, 11 September 2006 1:57 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Displaying LABEL with an ANGLE column
value
Greetings list,
Am trying to label point objects from a SHP file in MapServer and have
them appear at an angle drawn from an attribute column. I notice that
ANGLE AUTO only works with LINE objects and that ANGLEITEM is only
defined in the STYLE object. Is there a way in the Map file to get these
working together so the LABEL>ANGLE object uses the values defined in
STYLE>ANGLEITEM? I have had a look through the online doco and have not
come across a way to do this.
Many thanks in advance for help provided!
Regards
Julian Parker
Systems Analyst
Digital Mapping Solutions
Level 2, 2 Hardy Street
SOUTH PERTH WA 6151
Ph: 08 9474 6311 Fax: 08 9474 6411
Mobile: 0438 844 079
www.mapsolutions.com.au <http://www.mapsolutions.com.au/>
MapInfo Training
<http://www.mapsolutions.com.au/services/training/index.html> |
IntraMaps <http://www.mapsolutions.com.au/products/intramaps/index.html>
| InterMaps
<http://www.mapsolutions.com.au/products/intermaps/index.html>  |
MobileMap <http://www.mapsolutions.com.au/products/mobilemap/index.html>
| News <http://www.mapsolutions.com.au/news/index.html>
Disclaimer
This email and any files transmitted with it are intended solely for the
use of the individual or entity to whom they are addressed.
Although every effort has been made to ensure the correctness and
integrity of attachments that may be included in this email, this can
only apply to the unaltered/uncorrupted form. A copy of the original
attachment is available from our office should you require it.
Alternately, if further verification is required please request a hard
copy version.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060911/6bede256/attachment.html
