Displaying LABEL with an ANGLE column value
Manfred Meier m.meier at SPIEKERMANN.DE
Mon Sep 11 02:22:44 EDT 2006
some weeks ago there was a question like this on this list, if I
understand your question right. The answer was to use LABELANGLEITEM
with the name of a data column in the dbf-file.
In between I used this in an application and it works good. I use an
annotation layer with this command LABELANGLEITEM .
Manfred
Julian Parker schrieb:
> Greetings list,
> Am trying to label point objects from a SHP file in MapServer and have
> them appear at an angle drawn from an attribute column. I notice that
> ANGLE AUTO only works with LINE objects and that ANGLEITEM is only
> defined in the STYLE object. Is there a way in the Map file to get these
> working together so the LABEL>ANGLE object uses the values defined in
> STYLE>ANGLEITEM? I have had a look through the online doco and have not
> come across a way to do this.
> Many thanks in advance for help provided!
> Regards
> Julian Parker
> Systems Analyst
> Digital Mapping Solutions
> Level 2, 2 Hardy Street
> SOUTH PERTH WA 6151
> Ph: 08 9474 6311 Fax: 08 9474 6411
> Mobile: 0438 844 079
> www.mapsolutions.com.au <http://www.mapsolutions.com.au/>
> MapInfo Training
> <http://www.mapsolutions.com.au/services/training/index.html>| IntraMaps
> <http://www.mapsolutions.com.au/products/intramaps/index.html> |
> InterMaps <http://www.mapsolutions.com.au/products/intermaps/index.html>
> | MobileMap
> <http://www.mapsolutions.com.au/products/mobilemap/index.html> | News
> <http://www.mapsolutions.com.au/news/index.html>
> Disclaimer
> This email and any files transmitted with it are intended solely for the
> use of the individual or entity to whom they are addressed.
> Although every effort has been made to ensure the correctness and
> integrity of attachments that may be included in this email, this can
> only apply to the unaltered/uncorrupted form. A copy of the original
> attachment is available from our office should you require it.
> Alternately, if further verification is required please request a hard
> copy version.
