Question Regarding Perl Mapscript
Gabriel A Weaver
Gabriel.Weaver at TUFTS.EDU
Tue Sep 12 18:23:42 EDT 2006
Hi all,
I am trying to install mapscript for perl and run into the following error:
[terminal: ]$ perl -e 'use lib
"/web/cgi-bin/Progs/lib/5.6.0/i386-linux"; use mapscript; my $map = new
mapObj("DBs/MapData/world.map"); if ($map == null) { print "UTOH!";}
else { print "IT WORKS!";}'
Unfortunately, I keep getting "UTOH", indicating I have a null pointer
instead of a mapObj object.
So far I have: a) verified that the world.map file is in the proper location
b) checked permissions
c) rebuilt mapscript.pm after re-swigging.
Note, I am building with an older version of MapServer, a version from
1999, because I heard that MapServer 4 maps may not be fully compatible
with mapserver 3 data. Any help you could provide would be much
appreciated.
Thanks,
Gabe
