patch for SLD (vs. 4.8.3)
Rob Cermak cermak at SFOS.UAF.EDU
Tue Sep 12 21:21:13 EDT 2006
We have a patch for the SLD rendering for the colormap.  It seems that it is
documented to take doubles, but all floats passed via SLD become ints through
use of atoi.
This patch only takes care of the ColorMap.  This allows color rendering of
float values.
http://ak.aoos.org/data/patch/mapserver_483_mapogcsld.patch
If some change could work into 4.10, that would be great.
Cheers,
Rob
--- mapogcsld.c.orig	2006-09-12 15:30:39.000000000 -0800
+++ mapogcsld.c	2006-09-12 15:32:24.000000000 -0800
@@ -2354,6 +2354,7 @@
     char szExpression[100];
     int nClassId = 0;
     double dfOpacity = 1.0;
+    char *pch, *pchPrevious;
     if (!psRoot || !psLayer)
       return;
@@ -2403,10 +2404,32 @@
                         sColor.blue = hex2int(pszPreviousColor+5);
                         /* ?? Test if pszPreviousQuality < pszQuantity */
-                        sprintf(szExpression,
-                                "([pixel] >= %d AND [pixel] < %d)",
-                                atoi(pszPreviousQuality),
-                                atoi(pszQuantity));
+			/* pszQuantity and pszPreviousQuality may be integer or float */
+			pchPrevious=strchr(pszPreviousQuality,'.');
+			pch=strchr(pszQuantity,'.');
+			if (pchPrevious==NULL && pch==NULL) {
+			  sprintf(szExpression,
+				  "([pixel] >= %d AND [pixel] < %d)",
+				  atoi(pszPreviousQuality),
+				  atoi(pszQuantity));
+			} else if (pchPrevious != NULL && pch==NULL) {
+				  "([pixel] >= %f AND [pixel] < %d)",
+				  atof(pszPreviousQuality),
+			} else if (pchPrevious == NULL && pch != NULL) {
+				  "([pixel] >= %d AND [pixel] < %f)",
+				  atof(pszQuantity));
+			} else {
+				  "([pixel] >= %f AND [pixel] < %f)",
                         if (psLayer->numclasses < MS_MAXCLASSES)
                             initClass(&(psLayer->class[psLayer->numclasses]));
@@ -2456,7 +2479,15 @@
                 sColor.red = hex2int(pszColor+1);
                 sColor.green= hex2int(pszColor+3);
                 sColor.blue = hex2int(pszColor+5);
-                sprintf(szExpression, "([pixel] = %d)", atoi(pszQuantity));
+		/* pszQuantity may be integer or float */
+		if (pch==NULL) {
+		  sprintf(szExpression, "([pixel] = %d)", atoi(pszQuantity));
+		} else {
+		  sprintf(szExpression, "([pixel] = %f)", atof(pszQuantity));
Rob
Alaska Ocean Observing System
Database Manager
907-474-7948
