Line width and projection question
Christopher Watson
cwatson at UTAS.EDU.AU
Tue Sep 12 22:41:29 EDT 2006
I'm after a fix / work around to what is probably a common problem
when using geographic projections.
I'm using the WGS84 projection (epsg:4326) are there is no 'wrap
around' past the 180E/W meridian, i.e., if i center the map on 180E
then the western half of my global coastline shapefile will not show
(with the inverse is true if i center on 180W).
Tips anyone?
Appreciate your help.
Thanks,
Chris
