ogr2ogr: Command not found
Ryan Ollerenshaw
ollerery at ENGR.ORST.EDU
Thu Sep 14 18:14:27 EDT 2006
So i had to recompile gdal from the source in order to add support for
Xerces-C but after i did this i was still getting the same error so i
removed ogr2ogr from the /usr/local/bin/ directory and then recompiled
gdal again but now the ogr2ogr command is not being put back into the
/usr/local/bin/ directory. does anyone know what do i need to do in
order to get the gdal commands back in there.
Thank you,
-Ryan
