projection question
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Thu Sep 14 17:36:10 EDT 2006
Hi all,
I am trying to reproject some shapefiles using perl/mapscript. The
script seems to be working as I have used it with great success in the past.
So I have been trying various input and output projections using the
following definitions:
my $prjin = 'proj=latlong,ellps=clrk66,towgs84=89,-279,-183,0,0,0,0';
# NAD83
my $prjout = "init=epsg:4269";
# or WGS84
#my $prjout = "init=epsg:4326";
#my $prjout = "proj=latlong,datum=WGS84";
The data gets reprojected just fine but it seems to only move about half
the distance that I need it to, to lineup with my other data set. So I
have tried to push it a little further by changing the towgs84
parameters, but I can't seem to make it move! For example changing -279
to -1279 does not move the geometry relative reference geometry that is
not reprojected!
Any thoughts on how to get this to move using proj? It just seemed like
a better way to go than to add dx, dy to all the shape points by hand.
-Steve W.
