Strange map draw issue
Steve Hall steve.hall at MERCATORGEOSYSTEMS.CO.UK
Thu Sep 14 17:09:30 EDT 2006
Thanks Steve,
I suspect it must be a data or config based issue as the same server /
mapserver / web server is used (heavily) in other configurations with no
sign of this problem.  It's just this map file & database with the issue.
Steve H
Stephen Woodbridge wrote:
> Steve,
> How is your server/mapscript/etc configured. It sounds like you could
> possibly getting mapscript thread corruption or something similar to
> that.
> -Steve W
> Steve Hall wrote:
>> Sorry Ed, I must have forgotten to put that part in my email.
>> Yes, a simple refresh of the same map will, 9 times ot of 10, get rid
>> of the garbage.  But then at a random interval it will reappear (but
>> will be different garbage).
>> It's kind of hard for me to "post" the entire app, or allow access,
>> right now i'm afraid so I appreciate it may be hard for anyone to
>> help, I as just fishing for ideas really!
>> Thanks,
>> Steve
>> Ed McNierney wrote:
>>> Steve -
>>> I actually was asking if the output changed if the SAME map was
>>> refreshed - don't zoom in, out, or pan, just refresh the
>>> image/reload the page.  Does the same image request always return
>>> the same image?
>>>     - Ed
>>> Ed McNierney
>>> President and Chief Mapmaker
>>> TopoZone.com / Maps a la carte, Inc.
>>> 73 Princeton Street, Suite 305
>>> North Chelmsford, MA  01863
>>> ed at topozone.com
>>> (978) 251-4242
>>> *From:* Steve Hall [mailto:steve.hall at mercatorgeosystems.co.uk]
>>> *Sent:* Thursday, September 14, 2006 10:39 AM
>>> *To:* Ed McNierney
>>> *Cc:* MAPSERVER-USERS at LISTS.UMN.EDU
>>> *Subject:* Re: [UMN_MAPSERVER-USERS] Strange map draw issue
>>> Hi Ed,
>>> Thanks for this.  I may check my label columns in the database for
>>> NULLs and replace them with an empty string ('') instead.   It looks
>>> like a classic 'null' issue doesn't it?
>>> Yup - zoom in, zoom out, pan etc and the garbage generally just
>>> disappears, or changes its 'content'.   Often the angle is the same
>>> (suspicious) but sometimes not.....  There aren't any features on
>>> the angles so i'm not sure if it's a labelling issue or not.  Plus
>>> the problem only occurs about 1 in 20 or so map draws so is kind of
>>> hard to get a definite problem case.
>>> Checkout these additional ones :
>>> http://demo.mercatorgeosystems.co.uk/tmp/1158243616324003.png
>>> And just to prove it's not all CA....  ;-)
>>> http://demo.mercatorgeosystems.co.uk/tmp/1158244089248601.png
>>> http://demo.mercatorgeosystems.co.uk/tmp/1158244147717403.png
>>> Thanks Ed,
>>> Steve
>>> Take a
>>> Ed McNierney wrote:
>>>> Steve -
>>>> Well, just about anything in California is a little odd.....
>>>> Are you saying that if you simply refresh the image and re-draw the
>>>> exact same map you'll see this line of text change?  That's
>>>> puzzling.  I would speculate that it's a (garbage) text label for
>>>> some garbage feature - there's some feature that's defective in
>>>> both location and label (attributes messed up) and that feature is
>>>> being labeled.
>>>> The first thing I'd try is to eliminate layers from the image,
>>>> testing until the garbage goes away.  That could identify the
>>>> offending layer; if there are multiple classes in that layer, use
>>>> the same system to identify which class it is.  Then see if that
>>>> says anything helpful.
>>>>     - Ed
>>>> Ed McNierney
>>>> ed at topozone.com
>>>> (978) 251-4242
>>>> *From:* UMN MapServer Users List
>>>> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] *On Behalf Of *Steve Hall
>>>> *Sent:* Thursday, September 14, 2006 9:22 AM
>>>> *To:* MAPSERVER-USERS at LISTS.UMN.EDU
>>>> *Subject:* [UMN_MAPSERVER-USERS] Strange map draw issue
>>>> Hi All,
>>>> I've been using Mapserver for a while now, in a variety of
>>>> situations, but am seeing a slightly strange behaviour in one of my
>>>> setups.  Basically i'm getting a line of 'garbage' being drawn
>>>> across the generated map image.
>>>> A sample of what I mean is here :
>>>> http://demo.mercatorgeosystems.co.uk/tmp/1158239461914994.png
>>>> There is no road feature or other line that should be there, and if
>>>> I redraw the map the line of garbage will either disappear or
>>>> change in either length or 'content'.  It doesn't appear all the
>>>> time, but certainly enough to be annoying.
>>>> My MapServer version is 4.8.1, running with Apache 1.3.31 on Fedora
>>>> Core 4.  I've got several other MapServer based configurations on
>>>> this setup and they're all working fine.   The data source in
>>>> question is an Oracle 10g (10.1) database which is also used for
>>>> other systems and seems fine.....
>>>> Weird eh?  Any suggestions much appreciated!
>>>> Thanks,
>>>> Steve H
