Strange map draw issue
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Thu Sep 14 17:02:06 EDT 2006
Steve,
How is your server/mapscript/etc configured. It sounds like you could
possibly getting mapscript thread corruption or something similar to that.
-Steve W
Steve Hall wrote:
> Sorry Ed, I must have forgotten to put that part in my email.
> Yes, a simple refresh of the same map will, 9 times ot of 10, get rid of
> the garbage.  But then at a random interval it will reappear (but will
> be different garbage).
> It's kind of hard for me to "post" the entire app, or allow access,
> right now i'm afraid so I appreciate it may be hard for anyone to help,
> I as just fishing for ideas really!
> Thanks,
> Steve
> Ed McNierney wrote:
>> Steve -
>> I actually was asking if the output changed if the SAME map was
>> refreshed - don't zoom in, out, or pan, just refresh the image/reload
>> the page.  Does the same image request always return the same image?
>>     - Ed
>> Ed McNierney
>> President and Chief Mapmaker
>> TopoZone.com / Maps a la carte, Inc.
>> 73 Princeton Street, Suite 305
>> North Chelmsford, MA  01863
>> ed at topozone.com
>> (978) 251-4242
>> *From:* Steve Hall [mailto:steve.hall at mercatorgeosystems.co.uk]
>> *Sent:* Thursday, September 14, 2006 10:39 AM
>> *To:* Ed McNierney
>> *Cc:* MAPSERVER-USERS at LISTS.UMN.EDU
>> *Subject:* Re: [UMN_MAPSERVER-USERS] Strange map draw issue
>> Hi Ed,
>> Thanks for this.  I may check my label columns in the database for
>> NULLs and replace them with an empty string ('') instead.   It looks
>> like a classic 'null' issue doesn't it?
>> Yup - zoom in, zoom out, pan etc and the garbage generally just
>> disappears, or changes its 'content'.   Often the angle is the same
>> (suspicious) but sometimes not.....  There aren't any features on the
>> angles so i'm not sure if it's a labelling issue or not.  Plus the
>> problem only occurs about 1 in 20 or so map draws so is kind of hard
>> to get a definite problem case.
>> Checkout these additional ones :
>> http://demo.mercatorgeosystems.co.uk/tmp/1158243616324003.png
>> And just to prove it's not all CA....  ;-)
>> http://demo.mercatorgeosystems.co.uk/tmp/1158244089248601.png
>> http://demo.mercatorgeosystems.co.uk/tmp/1158244147717403.png
>> Thanks Ed,
>> Steve
>> Take a
>> Ed McNierney wrote:
>>> Steve -
>>> Well, just about anything in California is a little odd.....
>>> Are you saying that if you simply refresh the image and re-draw the
>>> exact same map you'll see this line of text change?  That's
>>> puzzling.  I would speculate that it's a (garbage) text label for
>>> some garbage feature - there's some feature that's defective in both
>>> location and label (attributes messed up) and that feature is being
>>> labeled.
>>> The first thing I'd try is to eliminate layers from the image,
>>> testing until the garbage goes away.  That could identify the
>>> offending layer; if there are multiple classes in that layer, use the
>>> same system to identify which class it is.  Then see if that says
>>> anything helpful.
>>>     - Ed
>>> Ed McNierney
>>> ed at topozone.com
>>> (978) 251-4242
>>> *From:* UMN MapServer Users List
>>> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] *On Behalf Of *Steve Hall
>>> *Sent:* Thursday, September 14, 2006 9:22 AM
>>> *To:* MAPSERVER-USERS at LISTS.UMN.EDU
>>> *Subject:* [UMN_MAPSERVER-USERS] Strange map draw issue
>>> Hi All,
>>> I've been using Mapserver for a while now, in a variety of
>>> situations, but am seeing a slightly strange behaviour in one of my
>>> setups.  Basically i'm getting a line of 'garbage' being drawn across
>>> the generated map image.
>>> A sample of what I mean is here :
>>> http://demo.mercatorgeosystems.co.uk/tmp/1158239461914994.png
>>> There is no road feature or other line that should be there, and if I
>>> redraw the map the line of garbage will either disappear or change in
>>> either length or 'content'.  It doesn't appear all the time, but
>>> certainly enough to be annoying.
>>> My MapServer version is 4.8.1, running with Apache 1.3.31 on Fedora
>>> Core 4.  I've got several other MapServer based configurations on
>>> this setup and they're all working fine.   The data source in
>>> question is an Oracle 10g (10.1) database which is also used for
>>> other systems and seems fine.....
>>> Weird eh?  Any suggestions much appreciated!
>>> Thanks,
>>> Steve H
